Old 07-27-2017, 08:27 AM   #1
Dave Castle
Dave Castle's Avatar
Default King Pins
How much, if any, play is acceptable in the king pins on a 40 pickup ? Right side has none, left side has approx. 1/32".
Dave Castle is offline   Reply With Quote
Old 07-27-2017, 10:50 AM   #2
19Fordy
19Fordy's Avatar
Default Re: King Pins
ZERO play is only acceptable as it only gets worse.
Old 07-27-2017, 11:14 AM   #3
drolston
drolston's Avatar
Don't disagree with zero play as the objective, but back in the day, the State of Virginia would pass up to 1/16th movement at the top of the tire,
Old 07-27-2017, 12:52 PM   #4
19Fordy
19Fordy's Avatar
That makes sense as 1/16 at the top indicates almost nothing at the kingpin assuming
the wheel bearings didn't influence the 1/16 finding..
Old 07-27-2017, 01:42 PM   #5
supereal
supereal's Avatar
It depends on where the slack is caused. If it is in the axle end, replacing or tightening the lock pins should fix it. If it is in the spindle, it is likely the bushings were improperly reamed. When the bushings are replaced in the spindle, the inside diameter of the bushing is reduced, making inserting the king pin difficult or impossible. They need to be sized to allow a hard hand push. We use our piston pin machine to size them, as a hand reamer often removes too much material. We advise all king[pin bushing to be sized by a machine shop.
supereal is offline   Reply With Quote
