Old 08-30-2016, 01:36 PM   #1
pgerhardt
pgerhardt's Avatar
Default One more step.
The cowl section of my 29 tudor is in epoxy primer. Primer surfacer tomorrow. Block sanding comes next. Then comes the color coat. Then finally I get to color sand and buff. I must be nuts! But at least being on the "barn", I know I am not alone.
File Type: jpg Screen Shot 2016-08-30 at 2.31.53 PM.jpg (51.7 KB, 94 views)
pgerhardt is offline   Reply With Quote
Old 08-30-2016, 02:51 PM   #2
C26Pinelake
Default Re: One more step.
Agreement with every statement! Wayne
C26Pinelake is offline   Reply With Quote
Old 08-30-2016, 03:10 PM   #3
Barber31
Barber31's Avatar
You surely are not alone. I'm doing some color sanding and buffing as well. Let me know if this link works.
https://flickr.com/photos/[email protected]
Congrats on getting closer to being done.
Barber31 is offline   Reply With Quote
Old 08-30-2016, 03:22 PM   #4
pgerhardt
pgerhardt's Avatar
The link works. That is a beautiful reflection. Is that base coat/clear coat?
Old 08-30-2016, 04:03 PM   #5
ericr
ericr's Avatar
to me the '29s, with the coupe pillar, the small hood, the front fender design, bumper design, etc. create a cute "antique" appearance to them. I know there are negative aspects to the 1929 models but I'm speaking merely of aesthetics.
anyway thanks for the pics.
ericr is offline   Reply With Quote
Old 08-30-2016, 05:19 PM   #6
Barber31
Barber31's Avatar
[QUOTE=pgerhardt;1346690]The link works. That is a beautiful reflection. Is that base coat/clear coat?[/QUOTE
It is a single stage. This was my second time doing a cut and buff. I'm always scared to ruin the paint but I just kept getting a little more aggressive till I started seeing results.
Old 08-31-2016, 09:48 PM   #7
pgerhardt
pgerhardt's Avatar
One of them is the 29 steering column. I solved that problem by having Randy Gross convert mine to the F-100 steering box!
Old 08-31-2016, 09:51 PM   #8
pgerhardt
pgerhardt's Avatar
[QUOTE=Barber31;1346740]
Great job then, but stop! You are right at the point where I go just a little too far and see primer! It is beautiful. Leave it alone.
Old 08-31-2016, 10:01 PM   #9
tbirdtbird
If you lay on 3 decent coats of SS or clear you should have enough to work with....when dry each coat is 1 mil, and you will color sand off 1 mil.
Too many newbies try to skimp on the paint....ya gotta have paint on there to work with....and passes should overlap 50%
'31 180A
tbirdtbird is offline   Reply With Quote
