Old 12-09-2015, 08:27 PM   #1
1955cj5
1955cj5's Avatar
Default Brass Black on shiny bolts
I like to use the old original bolts when possible but sometimes you just have to use those shiny new nuts and bolts. But they don't really fit in.
So I like to blacken them.I think it makes them look more like they belong....
I used them on the new head nuts and the water pump fake studs...
This stuff works on brass of course and most cad plated bolts. Won't work on chrome...
http://www.amazon.com/Birchwood-Case...ds=brass+black
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is online now   Reply With Quote
Old 12-09-2015, 08:38 PM   #2
Mitch//pa
Default Re: Brass Black on shiny bolts
the nuts are supposed to be cad or zinc...i would have left them
heat may affect the product possibly
Old 12-09-2015, 08:54 PM   #3
wrndln
1955CJ5,
How durable is the black finish? It would be nice to know if the items would rust after treating them in the Brass Black liquid. I am thinking about blackening unplated, i.e. beadblasted fasteners. I have used manganese parkerizing liquid, but the black finish tends to rusts after a while.
Rusty Nelson
Old 12-09-2015, 09:06 PM   #4
Larry Jenkins
To emulate the Raven finish, I clean and wire brush the fasteners, then heat them up with a torch until reasonably hot and dip them in used motor oil. Turns them a satin black.
Works well. Don't know the chemistry.. Nor why the "used" oil.
Larry
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 12-09-2015, 09:06 PM   #5
1955cj5
1955cj5's Avatar
I like them to look like they belong on an old car...not a hardware store shelf...
I have not seen any rust issues....but we are in a pretty dry climate here.....
Old 12-09-2015, 09:06 PM   #6
RonC
RonC's Avatar
It doesn't last and will rust immediately. You could coat them with satin clear paint. Professional phosphate is more durable
RonC is offline   Reply With Quote
Old 12-09-2015, 09:16 PM   #7
wrndln
Larry Jenkins,
Are you concerned that heating fasteners in that it might change the steels properties, like making them brittle, or other undesirable characteristics?
Rusty Nelson
Old 12-09-2015, 09:46 PM   #8
wrndln
Now Vince, be nice.
Rusty Nelson
Old 12-09-2015, 09:59 PM   #9
1955cj5
1955cj5's Avatar
Originally Posted by forever4 View Post
What technique do you use to get the spark plug bases the proper green color?
Proper Henry Ford Green from Brattons of course...the finest....
Old 12-09-2015, 10:13 PM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
After I blacken metal with gun blueing I quickly dry the parts and rub them with a rag soaked with ATF. Once a year or so I also use the ATF soaked rag to wipe down unpainted metal parts.
Old 12-09-2015, 10:18 PM   #11
Pete
Almost any nut or bolt can be had at a fastener store in "PLAIN" finish. It is black oxide finish.
Old 12-09-2015, 10:32 PM   #12
Larry Jenkins
Originally Posted by wrndln View Post
Larry Jenkins,
Rusty Nelson
Rusty..
No. You don't heat the fasteners anywhere near the point where it changes chemistry.
Larry
Old 12-09-2015, 10:41 PM   #13
Larry Jenkins
Hardware store regular stuff is probably Grade 2 fasteners. ACE hardware stores do carry Grade 2; 5 and 8.
Most of then original Model A fasteners are harder than Grade 2. Probably equal to the modern Grade 5.
I try to keep and restore all my original Model A fasteners.. As most of you do.
Larry
Old 12-09-2015, 10:43 PM   #14
Larry Jenkins
Vince.. Looks like you got a little careless with the Green spray "bomb."
larry
Old 12-09-2015, 11:43 PM   #15
Pete
Larry
HARDWARE STORES ARE NOT "FASTENER" STORES!!!!!
They are junk stores that handle Chinese shit.
A fastener store is one that handles ONLY nuts and bolts, like Tacoma Screw products or Cascade Screw Products.
Their stuff is made in the USA.
Old 12-10-2015, 07:45 AM   #16
Mitch//pa
From the company's FAQ page>>>
Q: What metals can Brass Black be used on?
A: Brass Black is used on yellow metals (brass, copper and bronze) ONLY.
Old 12-10-2015, 08:12 AM   #17
Vin-tin
Vin-tin's Avatar
Larry
I tried gun blueing and the hot oil dip method. I think the oil dip method works better. It doesn't rub off and if you burn off the first dip and heat and dip it again it gets real nice and dark. Water sheds right off too.
1929 Coupe
1930 Coupe
1935 Ford 5 window coupe
Vin-tin is offline   Reply With Quote
Old 12-10-2015, 08:51 AM   #18
Tom Wesenberg
How hot do you get the bolts for the oil dip method?
Old 12-10-2015, 11:09 AM   #19
1955cj5
1955cj5's Avatar
larry
For goodness sake those spark plugs are old and there just to fill the holes while painting etc....along with the rag in the distributor hole.....
It would be a good trick to paint the plugs but not the head nuts next to them....
Old 12-10-2015, 11:25 AM   #20
Tiny
Tiny's Avatar
HaHa
I was wondering about that cotton timing apparatus
I think your ideas a pretty good one. I wonder how it will last?
I do agree with you though, new bolts look like a dime on a goats ass in a "used" motor situation.
Blackwall Panthers
Nor Cal chapter
Tiny is offline   Reply With Quote
