Old 08-03-2015, 02:05 PM   #1
Hioridge
Default Ammeter doesn't show discharge with lights on
The ammeter on my 30 RHD Phaeton doesn't show discharge when I turn on the lights whether the car is running or not. It show charge of about 10-12 amps a road speed. There is only one wire,yellow/black, hooked to the cutout. The cutout is a rectangular box,about 1"x2"x1".
Something must be incorrectly wired ( I didn't do it!) Help!
Hioridge is offline   Reply With Quote
Old 08-03-2015, 02:20 PM   #2
Bob C
Default Re: Ammeter doesn't show discharge with lights on
There should be three wires at the cutout. One going to the junction box(which I
think you have), one to the horn and one to the light switch.
Bob
Old 08-03-2015, 03:13 PM   #3
Patrick L.
Patrick L.'s Avatar
A quick search here should provide a wiring diagram.
Old 08-03-2015, 04:02 PM   #4
mshmodela
mshmodela's Avatar
http://www.webjunk.com/modela/wp-con...amcolor2sm.jpg
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 08-04-2015, 11:14 AM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
It sounds like someone may have connect the lights to the starter switch instead of the cutout.
At the starter switch the ammeter would be bypassed.
Old 08-04-2015, 01:32 PM   #6
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Though NOT CORRECT, that would result in somewhat BRIGHTER lights.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-04-2015, 01:53 PM   #7
Blessyouboys
Blessyouboys's Avatar
Bill W.
Why is Tom's answer incorrect?
Blessyouboys is offline   Reply With Quote
Old 08-04-2015, 02:25 PM   #8
Bob C
I don't think he is saying Tom's answer is wrong but the way the car is
wired is wrong.
Bob
Old 08-04-2015, 02:37 PM   #9
Tom Wesenberg
Bill W.
Light brightness was never mentioned, and wasn't part of the question, but yes, it might make the lights a hair brighter because it bypasses the ammeter and a few feet of wire.
Old 08-04-2015, 02:58 PM   #10
BILL WILLIAMSON
Down in the DEEP DARK woods, people did a lot of "off the wall" things, to get BRIGHTER LIGHTS!---Heavier wire, shorter wiring, headlight relays, etc.
MANY folks would NOT EVEN travel at NIGHT! It was common, to have a car that didn't even have working LIGHTS! MANY didn't have the skills to repair them, or MONEY to pay someone to fix them. Chief once traded a light repairing job, for a 1/2 grown HOG! I tole you I wuz OLD.
Bill W.
Old 08-04-2015, 04:49 PM   #11
Blessyouboys
Bill W.
Did their ammeter show a discharge?
Old 08-04-2015, 05:31 PM   #12
SeaSlugs
SeaSlugs's Avatar
Down in the DEEP DARK woods, people did a lot of "off the wall" things, to get BRIGHTER LIGHTS!---Heavier wire, shorter wiring, headlight relays, etc..[/B]
Bill W.
This still holds true to cars up until about early 2000's. my 95 s10 saw a huge improvement over running 14ga wiring directly off the battery and using the old 18-20 ga headlight wires to drive relays. bypasses about 12 feet of wiring, wear and tear on headlight switch, and brighter lights.
after about 2000 every car already used a relay in the fusepannel under the hood and very little gain is noticed.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 08-04-2015, 06:00 PM   #13
redmodelt
redmodelt's Avatar
By the way, you should cut back the output from your generator unless you drive lots of short trips with your lights on, even then it might be a bit high.
Old 08-04-2015, 06:05 PM   #14
BILL WILLIAMSON
Depending on what they cobbled up, probably some DID & some DID NOT. Most "probably" didn't care, as long as it started every morning. My first Model A didn't even have a needle on the AMMETER, when I first got it! Found one from an OLD tractor
Bill W.
