hi
thank you for your time, well I have asked this ? be for but I will try again , and I am new to the model a and AAs. my truck is a early 30 with a 29 cab 131 1/2 wb 82-A stake bed 4 speed with the high speed rear end. OK here is my ? I am using the brake cross shaft that goes thru the frame rails but I do not have the levers that go on the ends and I have called all over the states trying to fine them no one has them, I am thinking I will just make them, but I need to know how far it is from center line to center line on all three holes on the levers and then I can do the machining on them. unless some one has a set they would like to sale. thanks again |
#2 | |
http://forums.aa-fords.com/viewforum.php?f=1
Nothing can be made foolproof, ---- fools are ingenious bastards. |
