The Ford Barn
-   -   cross shaft " levers " (https://www.fordbarn.com/forum/showthread.php?t=163776)
out back machine 03-14-2015 08:04 PM
hi
thank you for your time, well I have asked this ? be for but I will try again , and I am new to the model a and AAs. my truck is a early 30 with a 29 cab 131 1/2 wb 82-A stake bed 4 speed with
the high speed rear end. OK here is my ? I am using
the brake cross shaft that goes thru the frame rails but I do not have the levers that go on the ends and I have called all over the states trying to fine them no one has them, I am thinking I will just make them, but I need to know how far it is from center line to center line on all three holes on the levers and then I can do the machining on them. unless some one has a set they would like to sale. thanks again
Brian T 03-14-2015 11:42 PM
Re: cross shaft " levers "
Originally Posted by out back machine (Post 1050593)
hi
You may want to try over at the AA truck forums, I am sure some one has a chassis with a shaft still on it, as you only need the levers the shaft could be torched off saving drilling out the pins, good luck and regards Brian.
http://forums.aa-fords.com/viewforum.php?f=1
