Old 02-03-2014, 06:27 PM   #1
LopezCarguy
LopezCarguy's Avatar
Default after market king pins
Sure is a differance in price so is there a differance in quality...I'm talking about king Pins...mine need replacement..also wonder if there is way to tell if front axle is bent before assembling anything to it...thanks Dick
LopezCarguy is offline   Reply With Quote
Old 02-03-2014, 06:45 PM   #2
Steve Plucker
Default Re: after market king pins
I welded mine up about 25 years ago for my 1929 Standard Coupe, then I had them turned down to what they were originally...no problems as of yet.
Pluck
Old 02-03-2014, 07:50 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Do a search on "Bent Front Axle", or "Straightening Front Axle" and you should come up with a thread where Kevin shows 4 pins stuck in the front axle to check for bending.
Old 02-03-2014, 10:10 PM   #4
montanafordman
montanafordman's Avatar
Another easy quick check is that if you have everything off your axle it should lay flat on a flat surface. Its not uncommon for them to be bent from the spring perch outward. Mine was - some time with a 20 ton press fixed it and now my car drives beautifully and tracks straight with no wobble.
Aaron in T̶a̶c̶o̶m̶a̶ Meridian, Idaho
(although still a Montana hillbilly at heart )
1931 Coupe
1931 slant window sedan
montanafordman is offline   Reply With Quote
Old 02-04-2014, 07:48 PM   #5
LopezCarguy
thanks guy's, I made pipes to fit ( turned in lathe) the king pin holes...then smaller ones for the spring perches...then set everything up on flat surface...I have 7.5 inclination and both pipes are parallel...layed flat on flat surface there is no rocking..I think axel is good...Dick
