Can someone please tell me how to connect these tail light wires.
#2 | |
![]() Quote:
They look like aftermarket Fainstock bullets. They may plug into original Ford connectors.
Bruce
Works good Lasts long time |
anyone know where to get connectors
Bob Drake had them recently, also probably Third generation.
Napaonline.com
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
Yep. They will work but you will need to grind down the diameter a bit. As is, they will not fit the connector.
I was able to get them to fit recently without grinding. They are just tight.
40 ford coupe Build -https://www.jalopyjournal.com/forum/...coupe.1277406/ |
Aren’t those the light bulb contacts? Don’t look like bullet connectors. Wire looks correct for Ford taillight.
They do look like the british Lucas connectors that were used on all british motorcycles between the 50s and 70s - should be easy to find.
