11-07-2015, 06:32 PM | #1 |
Rear Crossmember/Spring ??
My ccpu has a pretty good lean to the drivers side, as many do, and it also had this patch job on the rear crossmember.. I could see it had more than 10 leaves but didn't know how many..it has 13! So it rode a little rough?
Anyway, here are a couple pictures of the crossmember some from underneath....so I need to remove it and replace it..I got a nice one on ebay and it arrived just today...along with the rivets and the setting tool from Big Flats Rivet Co. So, about the spring. I want to take it down to probably 8 leaves... How do I decide which leaves to remove? Every other one? I know you don't want to large a gap between the ends of the leaves...if anyone has a picture of an 8 leaf rear spring that would be great.. Thanks, Randy
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 Last edited by 1955cj5; 11-07-2015 at 06:46 PM. |
11-07-2015, 07:56 PM | #2 |
Re: Rear Crossmember/Spring ??
Regarding the spring, check out previous thread which starts by discussion of 10 leaves to 7, but considers 8 leaves.
https://www.fordbarn.com/forum/showthread.php?t=174402 Also has the all important "Spring Chart" originally developed by Marco of this board. Ford was ingenious in the way he made minimal spring size options cover a multitude of applications. As to the "lean", you may have issues with the frame beyond simply the rear crossmember. A quick test you might do would be to put the rear crossmember on a "point pivot" located at the mid-span of the rear crossmember, and check the frame for low point, twist along its length, or other issues. Sometimes frames are best scoped out after removal of the body. Also, a frame may appear straight, level, and square, but may be "sensitive" to loading, particularly on the drivers side. This would indicate broken rivets at the crossmembers. Its possible to use an attached lever arm to load "alternately" the frame and test for sensitivity: if the frame drops more on one side than the other, you may have hidden issues. Good luck with this. Joe K
Shudda kept the horse. |
11-07-2015, 08:19 PM | #3 |
Thanks Joe that helps..I have seen that chart somewhere before, and I think it had a"key" that indicated which colored line applied to which body style..
So If I had a 10 leaf I'd take out 7 and 9.....but how do I get from 13 to ten? I'm sure the answer will come along....
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 Last edited by 1955cj5; 11-07-2015 at 08:45 PM. |
11-07-2015, 08:52 PM | #4 |
I have an 8 leaf spring laying loose that I can take a picture of tomorrow.
11-07-2015, 09:07 PM | #5 |
That would be great Tom....I looked on the internet but got all sorts of pictures...
And if you would, could you measure the shortest leaf so I would sorta know where to start counting? Thanks, Randy
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
11-07-2015, 10:05 PM | #6 |
11-07-2015, 10:12 PM | #7 |
The crossmember is a mess, that is for sure....The spring pack bolt had no head, it was just round and tapered....maybe didn't even fit the hole I didn't try it. The top tapered leaf on the spring pack also had a section missing.....
I think several problems added up to the lean, the rough ride, and the "nose down' look when the truck was on level ground...
11-07-2015, 10:18 PM | #8 |
you have a few things to straighten out in the rear, but also make sure your front spring is not weak
11-07-2015, 10:22 PM | #9 |
Thanks Mitch, I replaced the front spring a few weeks ago...it had a 12 leaf in front and I replaced it with a new 10....
11-07-2015, 10:49 PM | #10 |
My Australian ute chassis has a 13 leaf rear spring. I was under the impression this was standard. I pulled several leaves out but it is still hard.
11-08-2015, 09:14 AM | #11 |
I removed two of the smaller ones..Forget exact ones. Eight remain on my wide bed. Made a big difference in how it rides. I installed a shim at the U bolt on left side. 1/4 inch shim raised left fender 1 1/2 inches. Bed is now level.
11-08-2015, 11:12 AM | #12 |
Randy, would it make sense to just look for another good spring like you want? There seems to be a number of them for sale on EBay and maybe Bert's will have a good one for you.
Fred Kroon 1929 Std Coupe 1929 Huckster |
11-08-2015, 11:47 AM | #13 |
Hi Fred, I've been thinking about that.....tomorrow I think I'll call the local club members that have helped in the past and see if I can find one....
According to the JS there was 13 leaf used on the 130 A & B...maybe someone would like to trade....8 leaf packs should be fairly common... Randy
11-08-2015, 12:08 PM | #14 |
Another interesting thing is the spring bottom plates that I took off are neither 5/8" or 1 1/8" which are the two choices offered by Bratton's
Mine are 7/8" high, and look like they were altered...Did the Model T use similar parts? Or maybe I'm measuring the over-all height and not just the support/center part?
11-08-2015, 03:44 PM | #15 |
Here's 3 pictures of my spare 8 leaf spring and rear end. Notice the bottom 4 leaves are thicker than the top 4. Notice the top leaf has beveled sides so it fits flush to the crossmember. Also notice the square head on the bolt needs to be turned 45* so it fits the square hole in the crossmember.
I measured the length be running my thin pocket tape across the top of the stack, but on the side of the center bolt. 1. 13 1/4" 2. 18 3/4" 3. 26 1/4" 4. 31" 5. 37" 6. 43 3/4" 7. 50 5/8" 8. Mainleaf The stack is 2" thick. |
11-08-2015, 05:22 PM | #16 |
Thanks Tom, that is excellent....I'll print it off and start measuring.
The square hole in my cross-member is squared with the sides of the crossmember, so no 45° ...i wonder if that was a change along the line somewhere? I'll let you know what i learn.. I did measure the width of the spring pack and the leaves are each 2 1/4" wide...and that agrees with Marco's chart..
11-08-2015, 05:24 PM | #17 |
what about buying a new spring
11-08-2015, 05:26 PM | #18 |
Mitch I might do that..it certainly has crossed my mind!...the more I look at this one the more wear I see at the ends of the leaves.....
11-08-2015, 05:40 PM | #19 |
i mentioned that because the only way i would go is new... take your old one to a swap meet it'll be gone in a New York minute
11-08-2015, 06:55 PM | #20 | |
So we took the bed off...my wife helped....it isn't too heavy but we stepped it down to the floor and put it on caster carts so I can move it around... Lots of things uncovered now.....oh boy...the cab mounting blocks look like something someone just stuck it there...they are all different....
