02-05-2024, 02:38 PM | #1 |
41 car steering shaft key dim
Hello, I’m writing to see if anyone can give me a hand and verifying the steering shaft Key dimension correct for a 1941 Ford car and a supplier
This is the key that slips into the steering shaft and slides into the steering wheels boss. I purchased a key from one of the Ford Parts dealer (C&G) , and when I got it, it was both (shorter in length And narrower in width ) in dimension The new key fell right out of the steering shaft and could not hold in place due to being too narrow and too short . This key has a width of 5/32” and length of 19/32” I believe a 3/16” wide x 3/4” long key is required Question = Did Ford have a special 3/16 with key to use on the shaft? If so, can anyone point me in the direction of a supplier to purchase this from? Thank you, John Last edited by 1963turnerjohn; 02-05-2024 at 02:48 PM. |
02-05-2024, 03:28 PM | #2 |
Re: 41 car steering shaft key dim
You are correct 3/16 x 3/4 .Cars with light rod the depth is 1/4 so it does not contact it
02-05-2024, 03:41 PM | #3 |
Thread Tools | |
Display Modes | |
