02-14-2021, 06:46 PM | #1 |
F-1 Brake/Clutch pedal support question
Looking at a bunch of play in the clutch pedal pivot..... brake pedal not as bad. Got the whole assembly removed from the vehicle.
I assume the pedals pivot on some kind of bushings, the ID of which is the shaft. How does this steel shaft come out of there? Has a mushroom head on one end and a grease fitting on the other. Looks like the shaft was originally pressed in when it was manufactured..... also looks like it may not have been intended to be removed, because I don't see an easy way to support the thing to press it out the opposite way. Has anybody done this job? |
02-14-2021, 07:16 PM | #2 |
Re: F-1 Brake/Clutch pedal support question
In the parts book is shows a pin at the grease fitting end of the shaft.
The shaft looks like part # O1T-7606 and the bushings B-7526-A |
02-14-2021, 08:00 PM | #3 |
Bushings are tore up inside. Looks like I'm driving over to the Early Ford Store tomorrow. Thanks. |
Thread Tools | |
Display Modes | |
