12-15-2020, 09:55 PM | #1 |
Gas Tank Restoration
Is there anyone currently restoring gas tanks. Mine has old sealant that has started to come off due to corn gas and rust.
Jamie Crosson 1929 Tudor Looking for an Original 888 Key |
12-15-2020, 10:18 PM | #2 |
Re: Gas Tank Restoration
Contact Brent Terry on this site. He has a great shop in Tennessee that can do a great job on your tank
Bob from Northport Northport, Michigan |
12-15-2020, 10:21 PM | #3 |
Thanks
12-16-2020, 02:20 PM | #4 |
previously, Brent mentioned that he doesnt have the time any longer to do tanks.................
12-16-2020, 05:04 PM | #5 |
I had read that
12-16-2020, 05:22 PM | #6 |
12-16-2020, 05:23 PM | #7 |
They do great work. did mine
12-16-2020, 05:40 PM | #8 |
e paintModel a tanks have baffles SO cut outs have to made to sandblast all interior areas. After sandblasted cutouts are welded back in,and sealer is installed.Then it is baked in an oven which destroys the paint. They then properly sand and primer. Their business card states Lifetme NO RUST Warranty. You then must have tank painted.
12-16-2020, 06:18 PM | #9 | |
12-17-2020, 05:44 AM | #10 |
The problem is getting the sealer out. Because of the baffles, unless you cut it open, you'll never be sure you've got it all out.
12-17-2020, 01:24 PM | #11 |
They charged me $450
12-17-2020, 01:24 PM | #12 |
Worth it
12-17-2020, 01:37 PM | #13 |
12-17-2020, 03:09 PM | #14 | |
I won't say my method is better than theirs, only that my method is probably a little more thorough (-since we can access & see 100% of the inside of the tank) ...and with my method, it is "more undetectable" when the tank is completely restored. As far as "not having the time to do them", like everything else going on in this world, we have such a backlog of 'other stuff' to do that the turn-around is longer than what most people want to wait. When folks start complaining about the length of time it is taking, then the easiest way to reduce my stress is to no longer offer that service. If someone is willing to wait, we have been, -and will continue to restore them. |
12-17-2020, 03:34 PM | #15 | |
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
12-17-2020, 03:37 PM | #16 |
I found this picture of one done by Moyer Fuel Tank Renu.
12-17-2020, 03:42 PM | #17 |
450 is a bargain.
thanks for clarifying the tank restoration Brent. |
12-17-2020, 05:49 PM | #18 |
I have had a number of tanks restored by Brents shop including my own car. He does an excellent job. I have seen the shop and procedure first hand, and it won't get any better.
If the car is worth it, it is worth the wait.
12-17-2020, 07:28 PM | #19 |
12-17-2020, 08:07 PM | #20 |
Brent, Thanks for the reply. I have no problem waiting. I’ll be in touch.
