02-11-2011, 10:39 AM | #1 |
39fordpickup
Does anyone know or have a picture of how the seats attach in the 39 pkp.the former owner tossed the seats.so i dont have anything to go by . I also need a winshield crank or parts to repair mine.
02-11-2011, 10:56 AM | #2 |
Re: 39fordpickup
I have a crank for sale on the HAMB, you need the mechanism inside the door right.
02-11-2011, 06:03 PM | #3 |
Re: 39fordpickup
No I need the WINDSHIELD crank or gear to repair mine.
02-11-2011, 07:55 PM | #4 |
Re: 39fordpickup
Tom Williamsburg is parting out 2 39's he has to have one of these, he has it listed here and on the HAMB. check the classifieds.
02-11-2011, 08:04 PM | #5 |
Re: 39fordpickup
Don't have pics up close on hand, restored a 39 1 ton & there is a hinge on the gas tank that mounted the bottom with cotter keys & there are slots in the cab bracing that iron pegs fit into that hold the plywood backing to the back of the cab. If you need pictures I can get some. Truck is put away for the winter.
02-12-2011, 08:19 AM | #6 |
Re: 39fordpickup
02-12-2011, 10:17 AM | #7 |
Re: 39fordpickup
The Hokey A$$ Message Board (HAMB) is part of the Jalopy Journal web-site that is run by the same fellow that is currently running the Ford Barn. There is a link to it in the Forums page.
Kerby |
02-12-2011, 11:55 AM | #8 |
Re: 39fordpickup
Is this Sunshine, Md? I am bringing a used seat to the meeting in Tues. eve to be viewed.
02-12-2011, 01:05 PM | #9 |
Re: 39fordpickup
My 38 has post that the seat drop on. couple holes to adjust.
The seat has hinges. I'll take my seat out today and take some pictures. Thought I had pictures of the seat when it was disassembled (just the wood platform and springs), but can't find it. The seat is reupholstered now and probably wont show as much as you'll like to see. Here is an old picture of the seat riser. |
02-12-2011, 02:01 PM | #10 |
Re: 39fordpickup
Here's what I have, this is for a 38. I don't know if it identical to the 39 but just about everything is interchangeable for the most part between the 38 and the 39.
02-12-2011, 03:13 PM | #11 |
Re: 39fordpickup
TINKER thank you for the great pictures , I can buy the springs from MACS or LABARON BONNIE , but I need to find the hinged brackets.
02-12-2011, 03:21 PM | #12 |
Re: 39fordpickup
Hey CECIL this is SUNSHINE ,MD. Im trying to get as much info as I
02-12-2011, 07:19 PM | #13 | |
Re: 39fordpickup
02-12-2011, 07:57 PM | #14 |
Re: 39fordpickup
04-13-2021, 03:12 PM | #15 |
Re: 39fordpickup
This is so helpful. My 38 1 ton does not have the riser and the posts are part of the tank. Do I just need a piece of wood at the back of the cab as shown above to hold the back up?
04-13-2021, 04:13 PM | #16 |
Re: 39fordpickup
Great detailed pictures by Tinker. Thanks for sharing. |
04-13-2021, 10:06 PM | #17 |
Re: 39fordpickup
As you can see the bottom of the seat is adjustable. 3 positions. Get out the truck and lift the bottom of the seat and drop into the hole that works. Grated the back of the seat didn't move much!
04-13-2021, 10:14 PM | #18 | |
Re: 39fordpickup
The standard 38-39 there is two metal pieces that run off the seat back spring that slides into a notch in the cab center band structure. I put some rubber tube over the seat extensions as the metal on metal was starting to create a metal squeak. |
