04-11-2020, 06:36 PM | #1 |
Part ID
Still finding things in my late Father's garage. All Dad wrote on it was 35 Ford sedan. Anyone know what it is? Anyone in need of it? Thanks in advance.
04-11-2020, 06:39 PM | #2 |
Re: Part ID
The 1st time i tried it said files were uploaded. Tried again and says upload failed. Hmm. Any advice?
04-11-2020, 06:50 PM | #3 |
Re: Part ID
3rd times a charm?
04-11-2020, 06:57 PM | #4 |
Re: Part ID
Just a guess but I would say spare tire mount.
04-11-2020, 07:00 PM | #5 |
Re: Part ID
Correct; spare wheel mount, 1935
04-11-2020, 07:43 PM | #6 |
Re: Part ID
04-11-2020, 07:49 PM | #7 |
Re: Part ID
It’s for a 34
04-12-2020, 10:38 PM | #8 |
Re: Part ID
Also same as 1933 pass car
04-12-2020, 11:43 PM | #9 |
Re: Part ID
Thanks for your responses. I have received conflicting results on the part ID. Dad masking taped on it many years ago "35 Ford Sedan" on the part. If I list it on the Swap Meet I wish it to be accurate. i recognize it's not a sought after part however I am unwilling to scrap a piece of history if someone wants or needs it. Dad knew his stuff about Fords so I'm inclined to believe it is indeed '35. If interested PM me.
04-13-2020, 12:18 AM | #10 | |
Re: Part ID
tomcarman……. For the 35 spare mount, you can find the part number embossed into the cast iron on the inside of the mount including the suffix letter "-A", "-B", or "-C". Three different tire carriers are listed for '35s depending on body type: 48-1433-A (models - 700, 730, 740, 750); 48-1433-B (models - 710, 720, 760, 770); 48-1433-C (model - 790). If indeed it is a '35 carrier, that embossed number will begin with a "48-" prefix. Can you find that embossed number? DD |
04-13-2020, 12:41 AM | #11 |
Re: Part ID
The first picture below is a '33-'34 carrier. It stands taller than the '35 carrier when sitting on a flat surface as shown. It's not as robust looking as the '35. The detail shapes are different. Compare the '33/4 in the first pic to your green '35 in the second pic. Like I said above, look for that "48-" prefix on your green mount! DD
04-13-2020, 09:03 PM | #12 |
Re: Part ID
If indeed it is a '35, that embossed number will begin with a "48-" prefix. Can you find that embossed number?
Thank you for the insight. I looked inside and sure enough there was a cast serial #, albeit obscured. I reached in there with a small wire wheel on the cordless and got a lot of crap off it. Upon inspection all I could identify was the veritical portion of what should have been the 4, I could definitely identify the 8 and the dash ( - ). Beyond that it appears the casting was made on a Monday. Think I'll just save it as a wall hanger as it appears there's no interest for it. I'd like to thank you for the excellent info and photos. |
04-13-2020, 10:46 PM | #13 |
Re: Part ID
Now that you have established that this Spare Wheel Holder is for the 1935 Ford, you now have to determine what body style it is for. You can see that they are different heights? The Part Number is cast inside, as per photo. Hope that this helps. |
04-13-2020, 10:54 PM | #14 |
Re: Part ID
Just as iin 1935, the 1936 Ford Spare Wheel holders also came in different heights, depending on which body style it was intended for. I know that the Grey one is off a 1936 Ford Phaeton. With these old Fords, you live and learn. |
04-13-2020, 11:21 PM | #15 |
Re: Part ID
Thank you Mercman. Interesting photos compared to the one I have. Your 1st photo shows the SN near the lip. The part I have the SN is down inside. Also, in the latter two photos the subject appears to be stamped, wherein mine is cast and much more stout. Also the SN in my piece is mostly obliterated from the casting. I wonder if Ford figured out a way to save a nickel at some point by stamping instead of casting, paricularly on overseas vehicles.??
04-13-2020, 11:30 PM | #16 |
Re: Part ID
Don't scrap it. give it away for the .10 cents you'll get from scrap.
04-13-2020, 11:42 PM | #17 | |
Re: Part ID
04-13-2020, 11:45 PM | #18 |
Re: Part ID
Sorry about your father. I get it. In the end all we have is the memories. Enjoy them!
04-14-2020, 08:38 AM | #19 |
Re: Part ID
Elaborating on V8COOPMAN's post, in addition to differences in height, the mounting surface where they attach to the body differs between them. The A-suffix version's mounting surface is convex, the B-suffix version's is concave, and the C-suffix version's is flat.
04-14-2020, 11:34 AM | #20 |
Re: Part ID
That DavidG guy knows some stuff, huh? DD
