I have just about everything you need to put together a running, driving chassis. Frame needs horns and a little straightening, practically pit free on the sides. Have 2 complete rears, complete front axle with wishbone, springs front and rear '40 backing plates and drums, hyd. brake master cyl. conversion, pedal assy, steering box with wheel, drop and column, firewall, complete hood, 2 trans. and parts, roadster windshield and posts(repo), 16" and 17" wire wheels, 1947 59A V8 complete(running engine when pulled and stored). Have other misc. parts including an original grille with insert(little rough). $11,500. Must pick up, I will not deliver. Don't call unless you are serious! I do not answer texts or emails, must call 845 392 5859 and leave message. I will send you pics if your serious
Thanks, Steve
