01-12-2019, 05:23 PM | #1 |
stromberg big 97
Any one using one of these?
Thinking about one for a 99a thats will be 265 ci Thanks Lawrie |
01-12-2019, 07:32 PM | #2 |
Re: stromberg big 97
How about small base 2 bbl. Rochester? Far better carb than a 97!
01-12-2019, 09:18 PM | #3 |
Thanks,but I want a new carb,less hassle ,
And the 97 looks the part Lawrie |
01-12-2019, 09:24 PM | #4 |
What is a BIG 97?
01-12-2019, 09:38 PM | #5 |
Dunno about the big 97,however Charlie on here supplied and built me a Big Holley 94 [lookalike- one of those later style carbs like fitted to a 272, but with a flathead sized base, that I fitted and ran successfully on a 284.
In a lot of respects, a Holley is a superior carb to a 97, particularly in a single carb application, and one of those babies would do the job nicely on a 265. IMHO
01-12-2019, 09:53 PM | #6 |
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 01-12-2019 at 10:24 PM. |
01-12-2019, 10:04 PM | #7 |
Same carb just bigger numbers. Size matters
01-12-2019, 10:11 PM | #8 |
So what's the difference except the big one being moldy.
01-12-2019, 10:20 PM | #9 |
No....Clive makes a special BIG venturi Stromberg 97; looks like a regular 97 but is totally bigger inside. For big cube engines.
01-12-2019, 10:37 PM | #10 |
SomStromberg BIG97 carburetors feature 55 percent increased airflow to put out a whopping 250 cfm! They have the same standard 97 outside shape, but use enlarged 1.175 in. venturi with a super-efficient 20 degree entry angle. The accelerator pump discharge jets are smaller, and flared exit cones build power by slowing down the mixture to reduce turbulence into the manifold plenum. The result is 250 cfm.
Stromberg BIG97 Tri-Power carburetors feature: * Signature 97 outside shape and styling * Cast iron base * Reinforced airhorn * Early plenum effect: allows all cylinders to draw from both barrels, giving you dual-plane drivability with a single-plane style top-end horsepower * New power valve circuits improve fuel conditioning: feeds top-end enrichment directly into the emulsion tubes * Ported distributor vacuum: switch in the brass plug (included) and connect your distributor to improve combustion efficiency in cruising mode; you'll run smoother and cooler, with more torque and better fuel mileage * Big S-jet twin-ball inlet valve: accepts 5/16 in. hard line and standard Stromberg fuel fittings * Four finishes available: original equipment style, chrome, chrome/black, or barn find (patina)e details of BIG 97 Stromberg : Phil NZ |
01-13-2019, 01:54 AM | #11 |
Brian, do those holleys have the power valve with a diaphram in it,not the mechanical one like the 97,s
Lawrie |
01-13-2019, 09:08 AM | #12 |
Hi Lawre
Sounds like a 4" crank and 60 over bore. Great combination. Yes the Big 97 would probably work just fine. Uncle Max might have more info. my biggest concern is the intake, can you bore it out to match the carb throttle bores. When I use the 2GC I bore out a Merc intake. On the stock car, I used a 33/34 intake and sleeved it. Well at least you'll have a much higher compression ratio. Might consider angle milling a set of heads as well. These are all old stock car mods when they had to look stock/ Take care Gramps |
01-13-2019, 12:12 PM | #13 |
The 2110 model (Holley 94 type carb) that was used in '56 on 272 Y-Blocks, has 1 1/16" venturi's and larger throttle bores, that also flow about 250 CFM. Might be cheaper than new BIG 97's.
They are all over EBAY everyday. Sal |
01-13-2019, 12:14 PM | #14 |
01-13-2019, 01:02 PM | #15 |
The 3-bolt Holley 2110 is a great carb for a larger cubic inch engine - should flow about 210 or so CFM. They made versions of the 2110 called a 'Bug Spray' for VW applications all the way into the 70's (though with a 4-bolt base). You should be able to pickup a 2110 for fairly cheap - just try to find the 3-bolt base version as noted by Sal up above(matches the 97 stud pattern). Obviously you'll need to 'port' your manifold to match the venture size.
01-13-2019, 05:18 PM | #16 |
The 'special' 2110 that Charlie built me had standard size throttle bores in the base - no porting was required
