05-23-2018, 02:50 PM | #21 |
Re: Crab 42-48 vacuum seal
05-23-2018, 05:29 PM | #22 | |
04-15-2020, 01:27 AM | #23 | |
04-15-2020, 08:19 AM | #24 |
The o-ring i use is square cut and is a left over from my fuel injection business , its a toyota injection seal . send me a envelope and i will send ya some ......
04-15-2020, 09:13 AM | #25 |
Jim,
Happy to see you are still at it, you are mister double D....... distributors and dialysis..........keep keepin' on. Charlie ny |
04-16-2020, 01:58 AM | #26 |
04-16-2020, 03:09 AM | #27 |
Following the comments of cast iron crab housings in this thread, I have one with a lug on either side, perhaps someone can identify it and the model it was used on, maybe industrial??? here are some images;
[ATTACH][ATTACH]IMG_3957.jpg IMG_3958 2.jpg IMG_3959 3.jpg[/ATTACH][/ATTACH] |
04-24-2020, 01:10 PM | #28 |
I used a easyout to get the rivet out. Is it normal to not be able to the piston to move with a hand vacuum pump? Seems like the piston for the brake should have a tighter seal in the bore? Thanks John
04-24-2020, 02:43 PM | #29 |
A hand vac pump would be tough based on pure volume we use a test benchg with vac pump .........the actuall seal never needed to be very good as the engine has good volume for the little piston size .......
04-25-2020, 04:34 AM | #30 |
Thanks Bubba..!!
