03-22-2018, 06:42 PM | #1 |
Model A Times Article About Not Using Diesel Oil
At the recommendation of many on the Barn, I have been using Rotella 15-40 oil in my Model A. A recent article in The Model A Times advocates not using a Diesel Oil. Has that changed the minds of any of you who like me have been using Rotella 15-40?
03-22-2018, 06:47 PM | #2 | |
Re: Model A Times Article About Not Using Diesel Oil
03-22-2018, 06:58 PM | #3 |
I will continue to use Rotella 15w40. Jeff
Let's let pylons, be pylons! |
03-22-2018, 07:38 PM | #4 |
I wouldn't use it simply because the detergents and additives are different for that oil from what a gasoline engine uses. Diesel engines develop soot that a gasoline engine does not.
Motor oil for gasoline engines states such, that it is designed for gasoline motors, on the label. People are in love with the Diesel Rotella because they think somehow the Fed. Govt. left it alone when they ditched ZDDP in SL and older oils. That's like saying in 1975, when lead was taken out of gasoline, 'Well, Shell still has lead so I'll use that." Like everybody else had to conform to No-Lead but one oil company did not. It has been talked about a lot, that you really don't need Zinc additives in a 4.0:1, low valve spring pressure Model A Ford engine. I've never heard of anyone having any problem using the SM motor oils in a Model A. And I don't think you will. But, if it makes you sleep better at nite, get some ZDDP additive and dump in the motor along with Rotella. |
03-22-2018, 07:49 PM | #5 |
I use ANYTHING that's the right viscosity, the right color, good smell & feels REAL SCHLICKERY!!!
Bill Happy
03-22-2018, 07:52 PM | #6 |
Here attached is a technical bulletin from the AERA Automotive Engine Rebuider Association on their research on the best oils for rebuilt engines using flat tappet / camshafts and the need for zinc.... Rotella T is one of the 3 suggested oils with sufficient zinc. At least for initial break in.... Oil wZinc info.pdf |
03-22-2018, 07:59 PM | #7 |
"Diesel oils" are formulated for both diesel and gasoline engines.
They are marketed mainly to the diesel engine fleet guys as a diesel oil, but they do also say you can use it in your gasoline engines, so you don't have to stock different oils (mixed fleet). Here is a copy/paste of a few small excerpts from the Chevron literature. Shell Rotella T is essentially the same: "Delo® 400 LE SAE 15W-40 is a mixed fleet motor oil recommended for naturally aspirated and turbocharged four-stroke diesel engines and four-stroke gasoline engines in which the API CJ-4 service category and SAE 15W-40 viscosity grade are recommended." "Delo® 400 LE SAE 15W-40 is approved for: • API Service Categories CJ-4, CI-4 PLUS, CI-4, CH-4, SM" <== SM is spark ignition engines "Zinc, mass % 0.13" . <== that is 1300 ppm, if you think zinc is important I have not had a chance to read the oil article in the MAT. I requested a copy of it from the publisher back in January but have not heard back. YMMV. .
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" |
03-22-2018, 08:00 PM | #8 |
Wait, so I shouldn't be using the oil I drain out of my diesel Blazer in my A? :-)
03-22-2018, 09:09 PM | #9 |
I just checked my containers of Rotella and the old Rotella T jugs had a SM rating, but my new containers of Rotella T4 do not have a SM/SN rating. Shucks
03-23-2018, 08:54 AM | #10 |
Did everyone hear the suggestion they WANTED to hear?--LOL
Bill Laffin'
03-23-2018, 09:18 AM | #11 |
This is not the first time I've read about not using diesel oils in the Model A engine. I have not read the Model A Times article. There was another article involving much research posted which appeared to have been written by a Model A enthusiast which came to the same conclusion. Unfortunately in that article the problems with diesel motor oil being used were implied and not based on any actual results. I like facts. Has anyone actually had any engine damage that they can show to prove that diesel oil like Rotella 15-40W does harm to Model A engines? I have not seen or read any yet.
03-23-2018, 09:38 AM | #12 |
I have not seen the Model A Times article, but what was their main concerns with using it?
Regards Bill |
03-23-2018, 09:52 AM | #13 | |
03-23-2018, 10:07 AM | #14 | |
03-23-2018, 11:05 AM | #15 |
I don't use or recommend diesel oil in my A, only in my diesel pickup. Something to consider, zinc was not in oils when the A was new. The A engine has a steel cam and only 40 lbs. of valve spring pressure. Zinc became important when the OHV V8's came into being. The only V8 not having cam-wear trouble was the Buick, because it had a steel cam. Use modern oil to keep your A engine clean and well-lubricated, better than when they were new.
03-23-2018, 11:29 AM | #16 | |
Right now Chevron and Mobil are still showing SM or SN on their equivalent oil to Shell Rotella T 15W40. But they, too, may bow to the EPA pressure not to label it for gasoline engines. That does not mean you can't use it in a Model A.
03-23-2018, 12:20 PM | #17 |
ive been using DELO 400 all along. 15-40 guess ill continue on
03-23-2018, 12:22 PM | #18 |
Search the net for a Hemmings article 10-18-2012 about the zinc/ phoshorous discussion. The article coincides with a study reported by the Porsche Club of America where 356 4 cylinder motors were torn down after testing and found similar less desireable results for the lifters, etc. with reduced ZDDP levels. The zinc rich oils were affecting catalytic convertors and some other parts and hence were gradually modified to suit modern engines.
03-23-2018, 12:52 PM | #19 |
duke36, please don't take this in the wrong manner but Porsche 356 motors are not Model A engines and I would not even try to identify the differences between them so it is a moot point. Also as we all know the Model A Ford does not have a catalytic converter......
03-23-2018, 02:40 PM | #20 |
This is a link to another discussion on Diesel oil in gas engines, this time the Jeep 4.0 which also has a flat tappet cam (yes, I realize the 4.0 isn't a Model A engine).
There were one or two posts about it's effect on catalytic converters. Been awhile since I read it but I remember it was very thorough. https://www.cherokeeforum.com/f2/rot...essing-188168/ |
