Old 09-07-2017, 04:10 PM   #1
3twinridges
3twinridges's Avatar
Default Hub cap removal tips
I just had the wheels on my 52 F1 build powder coated then top coated with two stage. Anybody have tips on hub cap removal to avoid scratching the paint?
JB
3twinridges is offline   Reply With Quote
Old 09-07-2017, 04:42 PM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: Hub cap removal tips
I use a plastic tool sold as a cheap set of 4 yellow pry tools for removing trim or door panels from HF. The one that works the best for my 40 hubcaps has one end that comes back more then 90 degrees (about 1/2 inch) and is like a miniature pry bar. I haven't marred any paint on my wheels in 4 years.
Old 09-07-2017, 04:43 PM   #3
ford38v8
ford38v8's Avatar
JB, I don't know if this is an option for you, but for '36 - '39 Spider hubcaps, I made a slide hammer type of puller: A simple steel rod with a hook on one end, a large loop on the other, and a 3/4" pipe nipple on the rod, to act as the hammer. It pulls directly on the cap, no leverage against the wheel.
Alan
Old 09-07-2017, 04:47 PM   #4
42 1/2ton
I have the same problem on my 1942 Commercial and purchased a tool from Bob Drake that is made for this and works great. It should be in there catalog.
Ed
42 1/2ton is offline   Reply With Quote
Old 09-07-2017, 05:01 PM   #5
42 1/2ton
In Drakes catalog it is called a Wheel Wizard and part number is TL110. If you go to there online catalog they even have a video on how it works.
Ed
Old 09-07-2017, 05:12 PM   #6
zzlegend
zzlegend's Avatar
Sometimes I use my paint can lid remover tool.
zzlegend is offline   Reply With Quote
Old 09-07-2017, 05:12 PM   #7
petehoovie
petehoovie's Avatar
Bob Drake Wheel Wizard video > https://www.youtube.com/watch?v=qkR83crQJN4
I purchased one of these to use on my '37 and it works like a champ....
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 09-07-2017, 05:12 PM   #8
3twinridges
Alright so the wheel wizard to get them off is a no brainer! How about getting them on? Any tips there?
Old 09-07-2017, 06:11 PM   #9
TagMan
Here a neat, easy to use wheel cover removal tool that I use. Available from Jeg's Summit. Amazon, Walmart, etc. Under $20.00.
555-80857 by TagMan, on Flickr
TagMan is offline   Reply With Quote
Old 09-07-2017, 07:29 PM   #10
Fortunateson
Great video but whoever that guy is he sure has an abnormally high voice for a dude!
Fortunateson is offline   Reply With Quote
Old 09-07-2017, 07:42 PM   #11
petehoovie
petehoovie's Avatar
Install them as normal using the heel of your hand. If your hubcaps are free of burrs there should be no problem. A little dab of Vaseline helps as well....
Old 09-07-2017, 07:50 PM   #12
Pat/Ohio
Pat/Ohio's Avatar
On the original style wheels & hubcaps for my '32s, I use one of those little yellow plastic bondo paddles. I just slip the thin edge of the paddle between the cap and wheel...sometimes I will use a screwdriver and wedge it between the cap and plastic paddle. You can buy the yellow plastic paddles at any swap meet. Very inexpensive. Pat
Pat/Ohio is offline   Reply With Quote
Old 09-07-2017, 07:58 PM   #13
Joe Immler
I also put a towel on the pavement. Inevitably one will slip out of my hands.
Joe Immler is offline   Reply With Quote
Old 09-07-2017, 08:24 PM   #14
3twinridges
Good thoughts guys, thank you.
JB
Old 09-07-2017, 08:27 PM   #15
3twinridges
I have to show them off a little!
Old 09-07-2017, 10:22 PM   #16
Alaska Jim
Alaska Jim's Avatar
What Deuce Roadster said. I have the same basic set, but mine came from the Mac tool truck. it works great on my '30 coupe with the 36 wide 5 wheels that are powder coated and '36 hub caps. have not dented one yet. the towel on the ground is a good idea in case one slips out of your hands when you are taking them off
Alaska Jim is offline   Reply With Quote
Old 09-07-2017, 10:46 PM   #17
VeryTangled
VeryTangled's Avatar
Hi Alan, Any chance of a photo of your tool? I'm not happy with my spider hubcap removal technique. Thanks.
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 09-08-2017, 12:32 PM   #18
ford38v8
ford38v8's Avatar
Hi Jeff,
This slide hammer can be used to bump the cap out in a very precise, controlled manner.
The only other way I know of to remove spider caps is with a long screwdriver from behind the wheel.
Alan
Old 09-08-2017, 03:25 PM   #19
JimG
JimG's Avatar
Deuce Roadster - is this the set you spoke about? $7.99 at HF.
https://www.harborfreight.com/Nylon-...-Pc-69668.html
JimG is offline   Reply With Quote
Old 09-08-2017, 03:35 PM   #20
flathead48
I always used a claw hammer, grab the lip of hub cap and just give a pull with one hand and catch with the other. Works great and never chips the paint on the wheel
flathead48 is offline   Reply With Quote
