12-08-2010, 12:03 PM | #1 |
cosmolene removal
Troops,
What is the best way to remove cosmolene? I have NOS distributor parts that need clean lup! Thanks |
12-08-2010, 12:38 PM | #2 |
Re: cosmolene removal
Solvent or mineral spirits will do it.
12-08-2010, 02:22 PM | #3 |
Cosmolene has a lot of paraffin (wax) in it so responds well to heat.
Here is an article about removing it with a hand steam cleaner: www.surplusrifle.com/shooting/cosmoline/pdf/cosmoline.pdf Here is one about removing it by baking in the oven: https://www.youtube.com/watch?v=rTzOWYdtcg8 Here is one about using mineral spirits and elbow grease. A bit more physical exertion than using heat: http://www.theboxotruth.com/docs/edu23.htm Good luck!
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
12-08-2010, 04:19 PM | #4 |
I get alot of parts covered with cosmoline. You can spend a day with parts clearners. Two ways to remove it. Real hot water will melt it. But this is what I usually do. I fire up my space heater, have a container of parts cleaner handy, hole the item with the cosmoline on it with a pair of channel locks in front of the burner from the space heater, the wax will melt right off, then slosh it around in the parts cleaner and it will be just like new. I can do a set of piston or bearings in no time. Just dont hold the item in front of the burner long enough to melt the part. Walt
12-08-2010, 04:26 PM | #5 |
If you have access to a vapor degreaser with trichlorethelyne in it,
holding it in the vapor for about 20 seconds will completely strip the cosmolene. Metal parts ONLY! |
12-08-2010, 04:56 PM | #6 |
Why do you remove cosmolene from the rings? Thanks. Jack E/NJ |
12-09-2010, 09:17 AM | #7 |
Location: Skaneateles,NY(summer)/Port St.Lucie,FL(winter
Long ago, in a land far, far away when I was in the Army, we used gasoline...
..."If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit"... |
Thread Tools | |
Display Modes | |
