07-06-2017, 11:21 AM | #1 |
Please recommend a Hinge Pin Removal Tool
I would like to know who is carrying a good robust hinge pin removal tool that can be used on my 1931 SW Cabriolet. Thanks for your help. Ed
07-06-2017, 11:34 AM | #2 |
Re: Please recommend a Hinge Pin Removal Tool
a punch from Sears?????????
07-06-2017, 11:35 AM | #3 |
I found this idea from another post and made something similar and it works great.
Before Walmart you had to buy a ticket to the fair to see a bearded lady! Last edited by RawhideKid; 07-06-2017 at 11:44 AM. |
07-06-2017, 11:43 AM | #4 |
have you looked at everyone of the model a suppliers what they all sell??
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
07-06-2017, 11:56 AM | #5 |
I successfully used the EXPENSIVE one from Brattons on my 68C after trying the cheaper ones then making a few per various web sites. NOT the $35 one in Snyders but I can't find a Brattons right now. It was CAST with a screw in pin that pushed mine right out permitting a right side mirror on my 68C.
07-06-2017, 01:09 PM | #6 |
Glen
'31 Model A Deluxe Roadster '31 Chrysler Model 70 Sedan '88 Pontiac Fiero GT '36 Auburn Boattail Speedster replica |
07-06-2017, 01:16 PM | #7 |
Good place for a dab of lock-tight! :-)
07-06-2017, 01:23 PM | #8 |
I have one like the one pictured above that I bought from Snyder's. It has worked great for me and several others in our club.
07-06-2017, 01:24 PM | #9 |
This is an area that I can unequivocally state that we have some experience in!
None of the pullers (pushers) on the market that I know of work very well. Therefore the 3 things we most commonly use (-outside of profanity!! ) is a liberal amount of penetrating oil first and then a punch on a 3X rivet gun to push it upward, - and if that fails to move it, then a drill. All we have found that happens with the commercially available pin removers is they 'spring'. Also understand that there is a point where the bottom of the soft pin 'mushrooms' due to the pressure and you are done anyway. Now here is the trick that generally works in conjunction with the punch. What happens is the pin wears and creates small offsets in the pin. Then the offsets hang coming out. Often times if you can get someone to lift the door at the edge to align the pin to go thru the hinges, then it will make progress. Sometimes you must actually rotate the pin to get it to move. Generally in this situation, use a small 12' long piece of flatbar with a hole in the end that will slip over the head of the pin. Then plug weld the pin's head to the flat bar so you have something to rotate the pin with. . |
07-06-2017, 07:55 PM | #10 |
:-) X-2 on rivet gun worked for me!
07-06-2017, 08:10 PM | #11 |
I just used the one from Snyder's had all the pins out on me door inside of 10 minutes
1930 Deluxe Coupe "Sister" |
07-06-2017, 10:16 PM | #12 |
I usually heat them with my torch and quench them a couple of times and then punch them out without a problem.
07-06-2017, 10:20 PM | #13 |
Sure is great for the paint job, I specially like the torch idea.
Before Walmart you had to buy a ticket to the fair to see a bearded lady! |
07-06-2017, 11:17 PM | #14 |
Tried all of the others on "stuck" pins and bent them all, made this one and found that it works really well
07-07-2017, 10:52 AM | #15 |
The ones from Bob Drake are a joke.
07-07-2017, 11:00 AM | #16 | |
07-07-2017, 04:06 PM | #17 |
I ground down a c clamp to a fitted point and used a deep well socket at the top----worked great'
Hotrods don't have valve covers |
