02-19-2017, 07:59 PM | #1 |
Grease Gun Storing
How do you men keep your grease gun from leaking grease on the Floor? I usually just lay mine on the floor out of the way on a rag. In cold weather it's not so bad but in the summer it is always slowly seeping.
02-19-2017, 08:03 PM | #2 |
Re: Grease Gun Storing
A good quality grease gun does not leak...
You may have grease on the bottom side of the rubber seal / plunger |
02-19-2017, 08:30 PM | #3 |
02-19-2017, 08:35 PM | #4 |
I leave my grease gun in the garage, since that's where I do my grease jobs.
It doesn't hurt to carry a small jar of grease, or a new tub of grease for the people that don't grease their wheel bearings, and break down while on tour. |
02-19-2017, 08:47 PM | #5 |
I have mine hanging on the wall with a specially designed tuna fish can shelf that the nozzle is placed in with a depth of 5/16" of an inch off the bottom of said can. Plans and materials list will be provided when 13 requests have been made. Wall hanger design is still being worked on for complete perfection and not available - nail length not yet determined. Design to address the leaks from the grease gun body and plunger are in the works. Above plans are for the nozzle dripping only.
John Last edited by aermotor; 02-19-2017 at 08:56 PM. |
02-19-2017, 08:54 PM | #6 |
02-19-2017, 08:57 PM | #7 |
Rob
Carl and i have the same one |
02-19-2017, 09:07 PM | #8 |
Thanks Mitch mine is a manual pc.
02-19-2017, 09:09 PM | #9 |
Sorry, didn't know the other post went through.
John Last edited by aermotor; 02-19-2017 at 09:13 PM. Reason: See message |
02-19-2017, 09:30 PM | #10 |
Put a plastic bag around it with a rubber band tie-if you have to take it with you.
Fred Kroon 1929 Std Coupe 1929 Huckster |
02-19-2017, 10:05 PM | #11 |
a recycled plastic bread bag and a rubber band from the Sunday newspaper helps keep mine sealed and safe!
1928 "A" Phaeton (mid year with many early features) 1933 "V8" Closed-Cab Pickup Truck (originally a Model B, 4 Cylinder dating to May, 1933)
02-19-2017, 10:28 PM | #12 |
Depending on the size of your gun I took a piece of PVC pipe and screwed it to the wall. The handle hangs over the edge preventing it from falling through. It keeps the gun upright and leaves no mess. Designed by Einstein.
02-20-2017, 12:52 AM | #13 |
I keep mine in my plastic oil drain pan - after emptying the oil I wipe the pan out with paper towel so the gun doesn't get oily.
02-20-2017, 03:00 AM | #14 |
hang mine on the garbage can with the hose to the inside
Hotrods don't have valve covers |
02-20-2017, 03:54 AM | #15 |
Rolled up in one of these and stowed in the bottom of my tool box.
I Love Anything That Turns Money Into Noise |
02-20-2017, 05:57 AM | #16 |
Solution against leaking grease gun in your garage :
Give it to your neighbour, and when you need it ask if you can use it. |
02-20-2017, 03:35 PM | #17 |
I store my drippy grease guns in a metal 5 gallon pail, hanging on the side w/the handle on the outside, the hose and grease chuck on the inside. There is also some big old oil cans stored in that pail.
02-20-2017, 08:45 PM | #18 |
Mine came with a cap. Hang it on a nail in the shed.
Paul in CT |
02-20-2017, 08:49 PM | #19 |
John, this is great, thanks for the chuckle...
"I have mine hanging on the wall with a specially designed tuna fish can shelf that the nozzle is placed in with a depth of 5/16" of an inch off the bottom of said can. Plans and materials list will be provided when 13 requests have been made. Wall hanger design is still being worked on for complete perfection and not available - nail length not yet determined. Design to address the leaks from the grease gun body and plunger are in the works. Above plans are for the nozzle dripping only." |
02-20-2017, 09:10 PM | #20 |
Seems many on here can use a grease gun upgrade,,,.
Then you'll be able to store it in ya tool boxes like i do... Last edited by Mitch//pa; 02-20-2017 at 10:43 PM. |
Thread Tools | |
Display Modes | |
