11-17-2016, 05:42 PM | #1 |
Number 1 cylinder on V8
We are working on a Ford V8 flathead engine. We have the heads off and a lively discussion was had about the number one cylinder. Is the number 1 in the front on the driver's side or on the passenger side? There is a bet riding on this one. Also we can't find torque specs for the heads and the intake manifold.
Thanks for your help. Marty |
11-17-2016, 05:53 PM | #2 |
Re: Number 1 cylinder on V8
I believe #1 is on the passenger side at the front.
11-17-2016, 05:53 PM | #3 |
Marty,the winner is...big drum roll......*PASSENGER*. It's an odd beast in that the leading cyl, that is the first conrod on the crank ,is not the first one in the firing order.
Gary |
11-17-2016, 05:55 PM | #4 |
11-17-2016, 06:04 PM | #5 | |
To avoid confusion, the #1 cylinder on a flathead Ford engine is always on the right side of the vehicle.
11-17-2016, 06:08 PM | #6 |
11-17-2016, 06:08 PM | #7 |
Go to this link for torque specs. > http://www.vanpeltsales.com/FH_web/f...rque-specs.htm
11-17-2016, 06:32 PM | #8 |
Passenger bank 1-2-3-4 driver bank 5-6-7-8 in the USA , unlike gm cars! Dave
11-17-2016, 06:43 PM | #9 | |
Also your firing order will be:1-5-4-8-6-3-7-2 |
11-17-2016, 06:47 PM | #10 |
Modern Ford`s are still numbered the same. 1 2 3 4 on the right side.
Tommy |
11-17-2016, 07:54 PM | #11 |
Thanks guys. We got the engine out tonight and the advice you all gave me will help more than you know. Also, this Van Pelt site has lots of good information.
Thanks again, Marty |
11-17-2016, 07:55 PM | #12 |
Oh, and by the way, I won the bet.
Marty |
11-17-2016, 08:42 PM | #13 |
I believe that the Ford flathead v8 is the outlier in that in almost all instances -- the cylinder farthest forward is #1. I don't know of another v8 engine other then our flathead 8 where #1 isn't the farthest forward. Anyone out there know of another?
11-17-2016, 10:25 PM | #14 |
Kube>>>To avoid confusion, the #1 cylinder on a flathead Ford engine is always on the right side of the vehicle.>>>
To avoid further confusion, which is the right side? And is the #1 cylinder the first cylinder on the right side in the back or the last cylinder on the right side in the front? 8^) For some reason I can only remember the flathead firing order as 18736542 and the GM-Chrysler firing order 18436572 with the cylinders numbered 1 to 8 front to back as they should be. Except of course some modern GM engines that went to the old flathead firing order for some insignificant reason that really escapes me. Jack E/NJ |
11-18-2016, 01:19 AM | #15 |
IMHO; Automotive wise,left or right is always derived from sitting in the drivers seat, not from standing in front of the vehicle looking at it.
11-18-2016, 05:02 PM | #16 |
When I went to wire up my Ford V 8, I used my past experience with Lincoln
V 12s. In the lincoln V 12 the furthest cylinder forward is #1 and that entire bank is odd numbered 1-3-5-7-9-11. I learned quick the the Ford is a different animal. |
11-18-2016, 06:50 PM | #17 |
11-18-2016, 08:35 PM | #18 |
Bored&Stroked>>>It is 15486372 >>>
Yes, with the cylinders numbered 51627384 front to back, 15486372 is then correct. But with the cylinders numbered 12345678 front to back, 18736542 is still correct. 8^) Jack E/NJ |
11-18-2016, 08:49 PM | #19 |
How about a flathead running a 180 degree crank. Order is 18364527. Sounds like 2 four bangers. Lots of fun......
11-19-2016, 12:15 PM | #20 | |
11-19-2016, 12:16 PM | #21 |
Exactly!
11-19-2016, 12:33 PM | #22 |
When I was in the USAF I was a firefighter. If you had a F4 come in with hung ordinance it was real important that everyone agreed which side was left or right. The USAF used "pilots left or right as they are sitting in the cockpit". Ford to this day uses the same but as you are sitting in the drivers seat.
11-19-2016, 12:41 PM | #23 |
"lively discussion" was had by all..
[QUO[/QUOTE]no matter where you are,or where you're at, there you are... |
11-19-2016, 04:03 PM | #24 |
The left wing is always the airplane's left wing, no matter which way YOU are facing.
R |
11-19-2016, 04:08 PM | #25 |
11-19-2016, 05:05 PM | #26 |
11-19-2016, 05:07 PM | #27 |
Hmmm. That must also mean my left arm is always my left arm, no matter which way YOU are facing. That's easy enough for me to remember. But what about my right arm? 8^) Jack E/NJ
11-19-2016, 05:34 PM | #28 | |
I won't go into listing all the cylinders - we'll just start on the front 2. In a flathead ford, the first cylinder on the passenger side fires first (#1), then the first cylinder on the driver's side (#5) - by Ford's numbering scheme. Number '8' will never be the first cylinder on either side - no matter which numbering scheme you use. Ford: Firing order = 1-5-4-8-6-3-7-2 FordNumbering.jpg Chevy: Typical SBC firing order = 1-8-4-3-6-5-7-2 ChevyNumbering.jpg |
11-19-2016, 06:59 PM | #29 |
>>>In a flathead ford, the first cylinder on the passenger side fires first (#1), then the first cylinder on the driver's side (#5)>>>Ford: Firing order = 1-5-4-8-6-3-7-2
Without numbering the cylinders, I prefer to say that the 1st cylinder on the driver's side fires 1st. Then the 4th cylinder on the passenger side fires next. Then the 4th cylinder on the driver side fires next but only for a typical Ford V8 --- it'd be the 2nd cylinder on the passenger side for a typical Chevy/Xler V8. Of course, for a right hand drive vehicle, I'd have to revise what I just said. 8^) Jack E/NJ BTW, as mentioned by V12Bill in an earlier post, the Lincoln V-12 numbering convention is similar to the Chevy/Xler logic with the designated #1 cylinder being the furthest cylinder forward, #2 the 2nd furthest forward and so forth and so on ad nauseum. |
11-19-2016, 08:13 PM | #30 |
This post sounds like an old Laurel and Hardy comic "who is on first" So many posts on Fordbarn by flathead owners that don't first get a manual on their car to do some basic research.
11-19-2016, 08:35 PM | #31 |
Speaking of basic research........"Who's on First" was Bud Abbott and Lou Costello......NOT Laurel and Hardy. DD
11-20-2016, 01:19 AM | #32 |
I did some BASIC RESEARCH and came up with "Who's on First"
https://www.youtube.com/watch?v=kTcR...cRRaXV-fg#t=26 .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
11-20-2016, 02:50 PM | #33 |
Here ya go, so nobody forgets your flatty's firing order! DD
11-20-2016, 03:38 PM | #34 |
v8coopman .... I have my Dad's 1938-ish Keystone (became "Firestone") 8mm home movie projector along with a short black and white silent sub-titled movie film by Abbott and Costello, doing their "Who's on First" routine. Still funny (to me) after almost 80 years. Only us old dogs remember such.
Maybe we should transcribed into a video and send it to oldford2 for his research |
11-20-2016, 03:49 PM | #35 |
Ahhhh.......He seems to already know pretty-much everything. And yeah, I still laugh my ass off every time I hear their "1st Base" skit! DD
11-21-2016, 07:57 PM | #36 |
11-22-2016, 12:11 PM | #37 |
left or right???Why not just use port & starboard?
11-22-2016, 12:25 PM | #38 |
I use port a few times a week. Have a few go to favorites.
R |
11-28-2016, 10:30 AM | #39 |
I love this site.
Only a group of old car guys could go from number 1 cylinder to Abbott & Costello. |
11-28-2016, 08:56 PM | #40 |
Y blocks are the same
11-28-2016, 09:42 PM | #41 |
boy , if you weren't confused before ,you should be now. what was the original question ???
11-29-2016, 04:14 PM | #42 |
11-29-2016, 04:24 PM | #43 |
And I'm still trying to find out if my right arm is still my right arm no matter which direction somebody else looks at it. Jack E/NJ
11-29-2016, 05:43 PM | #44 |
I have a glass of port in my right hand. Later tonight I won't care what hand it is in as long as it's port.
R |
11-29-2016, 09:01 PM | #45 |
I thought PORT was left, and STARBOARD was right. DD
11-29-2016, 09:19 PM | #46 |
11-29-2016, 10:51 PM | #47 |
12-04-2016, 06:37 PM | #48 |
Any PORT in a storm . . .
12-04-2016, 09:12 PM | #49 |
