11-11-2015, 11:36 PM | #21 |
Re: 4:11 ratio vs. 3:78
I replaced my 4:11 with 3:54, then switched from 21 inch to 16 in. wheels. I have a 26% Mitchell and this works well for me. That being said, I talked to Mitchell after the swap and he told me it would have been better had I brought him the OD and had him switch the gears from 26% to 36% and leave the 4:11 in the car. That was his thinking and I had to agree. With the 16 inch wheels and the 3:54 rear and the 26% Mitchell in direct i"m about the same as 3:78 with 21 inch, at 55 I;m fine with this set up, but could have saved myself a load of work and cost of the 3:54 gear for about the same outcome and changing the Mitchell to 36% wouldn't have cost as much as the gears and bearings I bought.
11-12-2015, 12:42 PM | #22 | |
11-12-2015, 01:48 PM | #23 |
i will add to put the trans in 3rd gear , removing the plugs makes it easier to turn
11-12-2015, 02:35 PM | #24 |
I changed the gear ratios from 3.78 to 3.54 in my '30 Phaeton and also in my '29 Tudor. I drive in the hills of the Pacific Northwest and the 3.54 was a best choice for me. I still can drive at 65 mph on the interstate.
11-13-2015, 11:11 AM | #25 | |
11-13-2015, 04:06 PM | #26 |
11-13-2015, 08:11 PM | #27 | |
You are not missing a thing.....I'm missing the $1K it takes to do all those things...this truck was basically free to me, but I've already spent a reasonable purchase amount on it.... But, I am getting insert bearings, SS valves, adjustable lifters, new pistons, rods and of course rings and all those necessary little things like an oil pump/distributor drive...sure-nuf laminated cam gear etc... A high compression head can be added later if needed..... The engine should be ready next week...!!!
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
11-13-2015, 08:14 PM | #28 | |
I think the error was in my interpretation of the results... My mark went to about 11 O'clock....so 3:78 is is! May this thread RIP......
