07-03-2013, 06:12 PM | #1 |
Rear window seals 1940 Ford coupe
Where do you guys get GOOD fitting rear window seals? Drakes are total crap. Carpenters may even be worse.
It's pretty obvious neither of these places ever actually tried to use their own seals.
07-03-2013, 06:40 PM | #2 |
Re: Rear window seals 1940 Ford coupe
Hi Mike, Yes you're correct, can't wait to find some good seals,wayne
07-04-2013, 12:32 AM | #3 |
Guys I bought from C&G and they fit perfect. I used a little dishwasher soap in a water spray bottle and had my Wife outside pulling on the thin rope and they popped right in. No probs and the size was correct.
Mike |
07-04-2013, 09:01 AM | #4 |
I agree that the Carpenter cpe rear seals are really poor fitting, but the two sets of Drake's rear cpe seals that I have recently installed fit perfectly.
07-04-2013, 09:07 AM | #5 |
Thanks Guys, My Drakes ( 7 years old now) will not stay flat on the top, close but not perfect. Wayne
07-04-2013, 09:16 AM | #6 |
dickspadaro.com |
07-04-2013, 09:20 AM | #7 |
I have drake seals in mine and they fit good.
Milt/Las Vegas |
07-04-2013, 09:31 AM | #8 |
I put a Drake seal in my 41 pickup and it fit great. Also have Drake seals in my 40 coupe and they also fit great. Dick Spadaro is right, it's the correct dimension of the glass that makes the seal fit correctly.
07-04-2013, 09:51 AM | #9 | |
The seals from Carpenter are obviously a good 1 1/2" too long. Drakes, at least an inch. Throwing stones? I think not. Telling it like it is? Yep... By the way, my glass (from Sanders) matches (exactly)the template that was provided with both the Drake and Carpenter seals. Next theory please?
"I can explain it for you. However, I can't understand it for you". Last edited by Kube; 07-04-2013 at 09:56 AM. |
07-04-2013, 11:14 AM | #10 | |
I'm currently restoring a 47 Cadillac at the shop and we are using Steele Rubber products, they are really high quality looking rubber pieces. Soft seal is another company I have used in the past and had good luck with. not sure if they offer rubber for the 40 though. |
07-04-2013, 11:19 AM | #11 |
Carpenters were a terrible fit on my rear 37 glass ,sent back. Same glass excellent fit with Drakes.Isn't 37 and 40 rear seals the same?
"Never complain,never explain"... Henry Ford II |
07-04-2013, 11:40 AM | #12 |
Kube, Go with C&G. The best in rubber products. Carpenter and Drakes..We wont talk about them. Ken
07-04-2013, 12:51 PM | #13 |
When I bought seals last at C & G they offered me Carpenter or Drake.
07-04-2013, 01:02 PM | #14 | |
07-04-2013, 01:03 PM | #15 | |
07-04-2013, 02:30 PM | #16 |
I've just fitted a Carpenter 41/48 rear window seal....perfect.
GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
07-04-2013, 02:58 PM | #17 |
Hey Kube, Just a thought here, but could they have been packaged wrong. Isnt there a difference in lenth between the coupe and sedan rear window seals?
07-04-2013, 04:04 PM | #18 |
I thought of that Ken. I don't have a lot of experience with sedans but aren't the windows smaller than a coupe?
07-04-2013, 05:15 PM | #19 |
07-04-2013, 05:38 PM | #20 |
MEMBER EMERITUS
Big difference between '39 sedan and coupe rear window dimensions.
07-04-2013, 06:22 PM | #21 |
The sedan uses a a larger seal. I also used Drake seals in my 37 coupe and they fit perfect in that car also.
07-04-2013, 10:34 PM | #22 |
I wasn't saying You had bad body work, just stating that it could be a problem, Anyway, If your cars consistently score 998 out of 999 You should be telling us where to buy good rubber!
07-05-2013, 08:02 AM | #23 |
Funny as heck..if only I knew!!!
07-05-2013, 10:09 AM | #24 |
We installed a set of Carpenters rear window rubber seals two years ago on a 1940 Deluxe coupe. Perfect fit. Also we installed a set of rear window seals on a 1940 2-door sedan, perfect fit. I bought a set of rear window rubbers for the 1939 Ford coupe we are presenly restoring. I will report on the fit of these. I have been buying rubber items from Carpenter for many years with no fit problems. When installing the seals, I am very cautious to prevent stretching the rubber. Good luck with yours! Tom
07-05-2013, 10:32 AM | #25 |
Drake's are perfect
07-05-2013, 10:36 AM | #26 | |
I am willing to bet "quailty control" has become an oxymoron.
07-05-2013, 10:37 AM | #27 |
07-05-2013, 01:59 PM | #28 |
Mike Kubarth! You could possibly be right on about a change in quality from some of these suppliers. In fact I bought a set of door window "whiskers" from Carpenter while I was in his store picking up the rubber seals. The window item was manufactured by Vintique! I am not happy to see that, and if I have trouble installing them, they will be returned for credit! We see too much "farming out" by some old Ford parts outlets. Tom
07-05-2013, 02:07 PM | #29 | |
I purchase the "raw materials" through Lebaron-Bonney and make my own. So far at least, the product quality has been good.
