05-04-2013, 04:57 PM | #1 |
B Distributor in a Model A and How to set the timing perfect?
Can anyone help me or lead me to an article or thread on this. I just bought a rebuilt and restored Model B Distributor for my model A (I like the centrifugal advance). I have a Model B timing cover so the timing pin will set up correctly on the timing gear and also drilled and tapped for the model A if I choose to go back, along with a pop out that has been cut and modified for both use....... But need to know the fool proof method IF there is one on setting the timing on this, and any fine point adjustment to make....any help would be appreciated.
and YES i have used the NU_REX centrifugal advance and still own one set to the Philips specifications and liked it very much, but that is not the subject. Mark
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
05-04-2013, 05:22 PM | #2 |
Re: B Distributor in a Model A and How to set the timing perfect?
msmaron ;
There was a post about two months ago from a fellow who said the stock model B dist ran retarded thus the reason for model B engines getting hot and blocks cracking around the valves . If this is correct I assume when your dist was rebuilt this issue was addressed. |
05-04-2013, 05:30 PM | #3 | |
05-04-2013, 05:38 PM | #4 |
Mark,
This may not be what you were looking for, & some may disagree, however, the following is a "vintage" detailed description from an original copy of: "Motors Handbook of Specifications, Interchangeable Parts Service Instructions for 1934", by Edward Barry, Service Editor of MOTORS, N.Y. City which covered many specifications for most automobiles made in the U.S. from 1927-1934: For the Model B Ford, after setting Model B points at 0.018" : 1. If not centered, loosen the screw on the spark control arm at rear of distributor housing, center it on the groove mark, & tighten screw. 2. Rermove timing pin, & insert opposite end in timing pin hole. 3. Crank engine while pressing on timing pin until pin slips in camshaft recess. 4. Remove distributor cover, rotor, & body. 5. Loosen cam locking screw on top of cam & turn cam until cam rotor slot is pointing towards distributor body No. 1 cylinder firing position. 6. Turn cam counter-clockwise until points are fully open; then turn cam clockwise until the points just close. 7. Stabilize cam with cam wrench & tighten cam locking screw. 8. Replace timing pin. Mr. Vince Falter has some detailed articles on same which are well written & explained. Last edited by H. L. Chauvin; 05-04-2013 at 05:39 PM. Reason: typo |
05-04-2013, 05:46 PM | #5 | |
05-04-2013, 05:58 PM | #6 |
I think there's something about the B where it's initial setting is something like 19* advanced but not sure. Hope this may help. Maybe also try PM'ng Purdy? Paul in CT |
05-04-2013, 06:10 PM | #7 |
Yes the initial setting is 19 degrees BTDC. The A cover and the B timing gear cover are different to accommodate this. You can also speak to the guys over at Renners Corner. They have parts and a great deal of knowledge about the B dist. I am rebuilding one now for a technical seminar for our club.
Oklahoma City Model A Restorers Group. |
05-04-2013, 07:31 PM | #8 |
here is the link to Vince's B distributor page
http://www.fordgarage.com/pages/bdistributoradvance.htm Initial setting with the engine not running is 19*. Note it describes the maximum advance as 36*. Given todays heads are much higher compression than the original Model B head, you probably want to avoid max advance beyond 28* if you are running a head around 5.5:1 compression. Also take into account that the origins of the springs on your advance are unknown, thus the advance curve described cannot be relied on until you verify it. If you do not have a distributor machine or a dyno, I would get a good degree scale that sits adjacent to the crank pulley and set a timing mark at 0 on the pulley. Start the engine and using a timing light, adjust the distributor so the max advance at normal running speed is at the degree you want it, for example, 28 degrees. This might mean it idles before 19 degrees. Once you get it on the road, the distributor has a small degree scale on the side that allows you to adjust the timing up or down a few degrees to suit its actual road performance. |
05-04-2013, 07:45 PM | #9 |
While the B dist may be fine for some,I much prefer to run the A dist on the B engine.I like to control the ignition myself.I run a 5.9 head on my 33 B.I do carry a spare pre-timed B dist that I can change out in about 5 min flat with a bullet connector between the terminal box & speedo-wiring tunnel under gas tank.I never usr the cable clamp on cyl head.
05-04-2013, 08:43 PM | #10 |
Mark,
Agree, each to one's own preference as to whether to install an A or B distributor -- it is your vehicle & you know what "you" want & do "not" want. I ran an A engine at one time & a B engine at another time in my same Model A with a Police Head & with B distributor for quite a few years without a problem. Reason: Had young guys my age, (at that time), borrowing it who I figured would never care about the spark advance position -- both ears always down & go. So I figured a Police Head with the centrifugal advance was a wiser choice in that particular case. Also not at all a bad idea if one has children or grandchildren borrowing or driving an A -- good chance they will soon not be concerned & pay no attention to the spark advance. With many Model A owners going for higher compression heads these days, it is easy to have uninformed drivers prematurely bang the babbitt out of the bearings. |
05-04-2013, 09:50 PM | #11 | |
05-04-2013, 10:01 PM | #12 |
05-04-2013, 10:03 PM | #13 |
Have you experienced pinging at 5.5+ CR? The manual advance of the A allows for up to 40*...do guys running HC heads typically back off the spark lever?
I was advised by my HC head builder to NOT advance it all the way down and I CAN'T without what seems like pre-ignition but must be POST ignition, but I can do sixty with it halfway down so I just don't drop it to seven o'clock. |
05-05-2013, 05:58 AM | #14 |
Yes,if they are smart.
05-05-2013, 08:47 AM | #15 | |
If you pay close attention, you can feel the engine over work even before it pings when the spark is too far advanced. Try it while not moving. Advance the spark at mid rpm range and you can feel the engine no longer increase in power when you go just beyond optimum, then as you advance further it will start to labor. Too much advance is aggravated when under a heavy load, like a steep hill climb or high temperature. I never go beyond 28 degrees anymore with a 5.5 or higher head. Most of the time I advance just beyond half mast with a Brumfield 5.9 head that has been surfaced a few times, so the compression is higher now. Last edited by pat in Santa Cruz; 05-05-2013 at 08:59 AM. |
05-05-2013, 10:26 AM | #16 |
With 19 degrees initial and a H.C. head I would avoid any hand-crank demonstrations. Even the automobile expert pictured below has had trouble with that.
05-05-2013, 12:01 PM | #17 |
Hi Mark,
As for hand cranking a Model B engine FWIW: We always timed our B distributor per reply no. 4 on this B engine with a B timing cover & a Police Head and "hand cranked" this engine more often than using the starter because of not being able to afford a new battery. This B engine, B distributor, B timing cover & Police Head came out of a boat used intermittently for about 20 years -- I remember the former owner hand cranking this engine in the boat by hand with a modified crank shaped like a torque wrench -- still have the wood boat & the modified hand crank. After timing per reply No, 4, never had engine "kick back" with either the starter or the hand crank. B engines came with a hand cranks because Ford designed them to be cranked by hand. If one advances the timing on any vintage engine more than that recommended by the manufacturer, and hand cranks this engine, no doubt it will be dangerous. Hope this helps with B distributor timing etc. Last edited by H. L. Chauvin; 05-05-2013 at 12:04 PM. Reason: typo |
05-05-2013, 12:47 PM | #18 | |
mark
05-05-2013, 01:36 PM | #19 | |
05-05-2013, 01:37 PM | #20 |
OK continue Tom please......??
05-05-2013, 01:59 PM | #21 |
Use a timing light. There's no "guessing" involved. You'll get it spot on, and you don't have to worry about it. Just my thoughts
Cowtown A's |
08-15-2018, 06:35 AM | #22 |
I just picked up a rebuilt short block that has about 300 miles on it. I also ordered a 6:1 HC head from Snyder. I can run an A distributor or I really want to use my B distributor. I like the idea, that another person can drive the car afterwards and I won't have to worry about how they use the timing lever.
I also bought the timing indicator. My plan is to mark my zero point on the lower pulley using the A timing gear cover, but then switch to the B cover. This way the initial timing will be a little advanced. But it will be close if I have to time it in a pinch. My question is; Once I get the lower pulley marked at zero, couldn't I use the timing indicator to set my initial timing at somewhere around 15* (before I start it) so the max advance of the B distributor might be closer to the desired 28*? Thoughts? thank you, John |
08-15-2018, 09:06 AM | #23 |
I agree with Pat's answer. I have found that if you check your timing with a timing light you will be off from TDC after using the pin method. There are various reasons for this that I will not go into. Splitting hairs is basically a moot point. In the A days anyone could time a "A" with the pin and be just fine. What I have learned over the years when setting up fuel and turbo pressures on aircraft is use the book for a base then close the book and make the system work. I am running 14 degrees initial advance with my B distributor and am happy.
08-15-2018, 09:44 AM | #24 | |
After I have it running for a while, with no vacuum or other leaks, then I can use a timing light to get somewhere around 28* at full advance. Because the engine is almost new, and I'm using a HC with a B dist. I just want to find a good place to set it, before I start it. I will be running the B cover after its finally timed correctly. John |
08-15-2018, 01:04 PM | #25 |
Why not put the B cover on it now and set the timing??
Paul in CT " I will be running the B cover after its finally timed correctly." |
08-15-2018, 03:57 PM | #26 | |
Next, switch to the B cover and bolt on the indicator. Then I can line my zero on the pulley with the 14* or 15* on the indicator. After that, I'd use the steps posted by H. L. Chauvin to set my distributor. I believe this would put my initial timing at 14* before I start the engine. John |
08-15-2018, 05:24 PM | #27 |
I wouldn't waste my time putting an A cover on and then a B cover. Get a copy of the service bulletins 1932-1937 and read on page 21 and 22 how to set the timing. Also read page 104 and 107 of those bulletins. You will probably get too much total advance and need to limit that if it pings.
08-26-2018, 05:07 PM | #28 |
My engine came with an A cover installed so, it was no bother to check it at zero degrees. Basically bolt the new timing indicator to the cover and find the indent and mark zero on the pulley.
Next I checked my mark on the pulley to the B cover to see if it was at 19*. Like Daren said, it was close but not perfect. I checked my mark with the head off using a mag base and a thousandth indicator to TDC on piston #1. My mark on the pulley was at 1 degrees. But when I accounted for backlash it would be close to zero degrees. I bought a copy of the 1932 to 1937 Service Bulletins. Page 21 seems to match post #4 in this thread. Not much different. Parts of pages 104 through 107 go into detail about finding TDC. I didn't really need to buy the book for that. I already had the engine installed before the book arrived, so I set the timing at 14* (because of the HC head) and set my B distributor like step #6 in post #4. A little choke and it started right up and idled on the first try. After it warmed up I checked my initial timing with a light, and it says it's at 15*, when I increase my rpms to what I think is around 2,000-2,200. it bounces around 29* and 30*. When I drive it down the road at 45 mph it has plenty of power, I can't hear any gas knock like it's advanced too far. Even though the initial timing reads 15* and is 4* retarded, it isn't sluggish at low rpms. I think I'll leave it at 15 degrees. Thank you all for your advice, John |
08-26-2018, 10:14 PM | #29 |
Set by the book then close the book and readjust to your liking. I ended up with 14 degrees advance on startup. I found that using the pin can be off up to two possibly three degrees when checked with a timing light.
08-26-2018, 10:28 PM | #30 |
If you use a timing indicator do not use the timing pin to mark the crankshaft pulley, Use the piston at TDC.
