#1 |
We have a 30 that we are having trouble with its sputtering and backfiring at half to full throttle. we eliminated the tank by running an aux. fuel tank. changed carbs.(have 3)installed a brand new distributor.modern which we were running before. Retimed and set points. getting spark to all cylinders. Any suggestions? also the new distributor came with new points and condensor..
#2 |
Try a coil might be breaking down under load.. can also put an in line spark tester to cap and look for int or weak spark
#3 |
Sounds like an air/fuel mixture problem - intake manifold gasket leak ?
Would have suspected GAV mixture problem, but not likely on all 3 carburators |
#4 |
Thanks fellas, do you think it could be a valve problem? car not run that often, only in the summer in NJ.
#5 |
could be alot of things even an exhaust pipe restriction from varmits
coil wired backwards am shying away from manifold leak because it runs good at idle up to 1/2 throttle Last edited by Mitch//pa; 08-28-2012 at 06:17 PM. |
#6 |
Paul in CT |
#7 |
A vacuum guage can tell you a lot.
#8 |
Had one like that. Had a bad plug breaking down under load. Try a new set.
http://www.model-a-ford-4bangers.com/ Last edited by James Rogers; 08-29-2012 at 10:55 AM. |
#9 |
New Motorcraft plugs cured mine.
#10 |
Sounds like you have done a lot to narrow it down. I like Mitch's suggestion to swap coils and see what that gets you. You can also use the wd-40 test and spray it around the intake to see if it affects how it runs. This would indicate a manifold leak. You say it runs great at idle which in my book would eliminate valve timinig but would be worth checking.
Oklahoma City Model A Restorers Group. |
#11 |
Tom, where do we put the vacuum gauge?
#12 |
did try swapping coil wires, got worse.lol ears still ringing ....
#13 |
running champion w18's good plug?
#14 |
18's are good plugs but I like the W16Y better. Both champion. I would just about bet it is a bad plug.
#15 |
#16 |
How old is the gas? And even tho you have anew condenser in there, you might try another. Also check your GAV for 1/2 open while cold, 1/4 open when warm.
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. ![]() |
#17 |
what should the readings be on the vacuum gauge?
#18 |
A good running engine should show about 18 to 22 inches of vacuum. My 28 doesn't have a vacuum port, so I can't easily connect my guage. What you are looking for is a steady reading. If it's steady at idle, but starts to flick at higher speeds, that would indicate a sticky valve not closing as it should.
If it's steady and near normal at idle, but drops off while staying steady at higher speed, that could indicate a restricked exhaust. |
#19 |
A very informative (to me) link concerning engine diagnosis using a vacuum gage was provided in reply 21, posted by HoarseWhisperer to the 4/19/12 “Why does my engine die when stopping?” thread. The link is:
http://www.classictruckshop.com/club...ts/vac/uum.htm.
Skip Keyser Napa Valley A's Olympic Vintage Auto Club (1980-1982) MARC of San Diego (1977-1978) MAFCA (since 1978) MARC (since 1977) ---------- Model A owners belong in their Model A’s; Model A’s belong on the road. |
#20 |
Thanks for the chart, That's a great tool to help us all
#21 |
Sorry for the late reply, just to lyk. It was the coil! running great again! thanks for all the replies.
