#1 |
Does anyone have any experience with the rear hub puller being sold by Vintage Precision? It is advertised as an enhanced reproduction of the K.R. Wilson ABV-156 rear hub puller and looks pretty good for less than $100.00. Just wonder if it will work as well as the original? Check it out at www.vintageprecision.com
#2 |
Looks good to me. But, if you only need to pull a hub once in a blue moon you can rent a puller from AutoZone for free to do so.
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
#3 |
Why fix something that isn't broke? For just a few dollars more, you can have a KR Wilson Hub Puller.
The KRW AB-156 is the best thing since chocolate. Henry.... I'm surprised at your response! You're gonna pull the hub or are you gonna pull the studs from the hub?
Alan Last edited by ford38v8; 03-18-2012 at 10:30 PM. |
#4 | |
![]() Quote:
If you want to see what you can rent for free to do what only rarely needs done look at puller #27078 here: http://www.autozone.com/autozone/ino...llersUniversal It's the first one listed. #27011 works too. It's just not quite as versatile.
#5 |
The Vint. Pres. puller looks real good... I got the KRW, love it..
Good not to cheap out on this, one time can ruin a good axle... Karl |
#6 |
36 1/2 ton pickup on 38 car frame with 1940 v8 24 stud |
#7 | |
![]() Quote:
Looks pretty good. But, I always wonder (about credibility) when I see something like that hub & drum that is labelled 1939. Maybe it's just me, I don't recall seeing a 39 hub/drum that looked like that. JMO |
#8 |
looks pretty good....definitely not a '39 Ford drum, tho....no wide five there....Mike
#9 | |
![]() Quote:
Hold your mouth wrong and you pay for a new axle. Hold your fingers wrong and you pay the E.R. Doctor.
Alan |
#10 | |
![]() Quote:
#11 |
I made what I consider to be a nice rear hub puller and posted pictures of how it works, etc., here on the new barn and on the old barn as well. I'm away from home right now and my computer files but could post something again when I get back home or I could email/pm those pics to you.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 03-19-2012 at 03:35 AM. |
#12 |
I too made my own, being an Industrial Blacksmith by trade helped. When I went to use it, the first rear hub on my new '36' pickup came off after just one revolution of the screw, the other rear hub took two revolutions. I figure the ft Ib's of torque on the hubs were practically zero. Still, I have it for next time.
Lucky I didn't drive it without first checking out the brakes (a standard proceedure for my mechanic). I also agree with Old Henry, 'as needs must' while it's a comforting feeling to have the correct tool, any other tool which can do the job properly and safely should also be considered. If you can borrow one even better. |
#13 |
Well, has been posted before! The way I did it!
/Jorgen |
#14 |
If I was pulling my rear hubs once a month I'd definitely get the KR Wilson as it looks a lot easier to use but I only pull them every 10,000 miles to grease the bearings and change the brake shoes. For me, that is "once in a blue moon" and I'll keep borrowing from AutoZone for those rare occasions. Is there some reason others of you are pulling your hubs all the time? Something I should know?
#15 | |
![]() Quote:
#16 |
Vintage Precisions works just fine except: Vintage Precision's Rear Hub Puller will only work on grooved design hubs and not on protruding ring style hubs.
It's 110 miles to Chicago We've got half a pack of cigarettes It's dark And we're wearing sunglasses Let's go. |
#17 |
Old Henry ,I like knowing ways to save money .Now days we need all the shortcuts we can get.I got the cheaper one from Macs and have used it several times with no problems,I thing if I was pulling them all the time I would spring for the other but right now I dont have an extra $200 laying around.I like the fact that you can get all kinds of advice on here thats how we learn.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. " |
#18 |
if your going to spend 100 for a toy puller go the extra & buy the kr wilson one advertized in the v8 times it workes & remember when you trade your old ford for a rocking chair you can sell it for near what you paid for it that pipe & bolt thing after you wacked it a few times will not look so good i have seen rear hubs so tight that they can bring tears to a glass eye. you don,t go bear hunting with a 22
#19 |
Thanks for all of the comments. When I saw the puller listed by Vintage Precision my first thought was that this is a good price for a club tool, one that would get a lot of use among friends. Then I wondered about the quality of the item, the hardness of the steel and how long it would last under repeated use. At $100 I thought that this was a good price when compared to the $150 puller advertised in the V8 Times which I know to be a quality item. The puller sold by Mac's at $190 seems out of line price wise and I wonder who makes it. Does anyone have any first hand experience with the puller made by Vintage Precision? For a club tool this is the best price at $100 but only if it lasts under repeated use.
#20 |
I did this one for $75 http://macsautoparts.com/search.asp?...113t&x=19&y=12
Has been working just fine
#21 |
Hi Scott, Did not know this item existed, I only saw the more expensive one from Mac's. Now there are 4 choices for a puller. This item looks like it will do the job just fine using the same principal as the others and at a lower price. Thanks for the information.
#22 |
I used the KRW puller on a Ford rear, the drums were last off in the early 50's... With an air wrench, heat (lots) and a 3 lb. hammer... It would NOT come off... Period.
I wound up taking an abrasive wheel to the hub- along the length of the axle, on top of the keyway... And, full on again with the air wrench and hammer, it popped off. Point is, any other puller would have been toast. For the KRW puller, just another day at the office... Karl |
#23 |
i have never saw a hub that the krw puller could not pull. karl you should of used a 10 lb sledge 3 lb hammer onley gets it mad if it,s realey frozen .don,t be affread to hit it you woun,t brake it . it is the best money can buy the other is an attempt there are two things in life that can,t be inproved. 1-is the krw puller the other is some thing a woman has
#24 |
The Vintage Presion, what holds the 2 halves of the puller,it dosen't show any thing in th pics[a sleeve or something ???? ken ct.
#25 |
Yes. The sleeve is what's laying behind the half that's laying down. When the sleeve is on it looks like the top image.
#26 |
#27 |
Hi Scott, What you have is the puller made by Winfield Tool Works. This is a super puller and is a reproduction of the KRW puller made years ago. I was asking about the puller made by Vintage Precision which seems to be an excellent copy of the original puller made by KRW and your puller made by Winfield Toll Words. The price for the Vintage Precision puller is less than the other two and I was hopping that someone that had one could attest to the quality of the steel used in its manufacture and its ability to stand up as a club tool after multiple uses. Best regards
#28 |
Macs sells a knock off hub puller for $2.90. I do not own this particular one but i have an original one from back in the 30's and it works great. Scew it on the axle till it bottoms out and leave the wheel on the ground that you want removed and hit with a sledge. It works every time for me. They recomend that you jack the wheel off the ground on the opposite side from the one you want removed. Marv
#29 |
On one of these sites someone said they went to Harbor Freight and bought one of their gear pullers with 2 arms. I was in HF recently so I thought what the hell, it's less than $13 so I bought, came home, tried it and it worked fine.
#30 |
If you want to go the harbor freight route but the pitman arm puller & relieve the center to fit the hub. Works good & better than pulling on the studs. I think it cost less also.
#31 | |
![]() Quote:
I did get it off, though Karl |
#32 |
The altered Harbor Freight pitman arm puller worked great for me. I had to grind the jaws a bit to get it to fit over the hub, snugged it up and a few taps with a hammer and off popped the drum. Its worked on a number of hubs so far.
#33 |
The Winfield Tool Works puller can't be beat. I have had mine for many years. I know they are expensive, but there is no such thing as good, cheap, tools. A bent drum or ruined axle threads is not cheap!
#34 |
This is an old thread recently bumped.
I use the Vintage Precision version as it was available and to me a reasonable price. I show it in use in this video. https://youtu.be/i26ZSqwFIF0 In the video I state that if you don't think you are going to break something when tightening it, the hub wasn't tight enough. I stand by that. If you are using an inferior puller if it feels like you are going to break something, you probably will. Mart. |
#35 |
This was posted on HAMB in 2012. Read the last sentence of this post.
Winfield Tool Works makes the relica of the KR Wilson Tool. Just so people know, Winfield Tool Works still produces the hub pullers. My father was the owner and my brother has taken over. They are exactly the same and are still produced by the same manufacturer. New Address. Winfield Tool Works can be reached at 3 Enterprise Drive East Setauket, NY 11733-3724 Phone: (631) 928-3316 Fax: (631) 928-3221 Here's one for sale on Ebay at a very good price, so far. I paid $150 new 10 years ago from Winfield. https://www.ebay.com/itm/1939-Ford-K...0AAOSwHGtdvcNf Last edited by 19Fordy; 11-05-2019 at 06:18 PM. |
#36 |
What's the current price of that beauty?
#37 | |
![]() Quote:
#38 |
#39 |
Unfortunately Winfield Tools discontinued the pullers several years ago and told me they had no plans to reintroduce it earlier this year. I got lucky and bought one on ebay and paid much more than the current one posted is at
#40 |
http://www.vintageprecision.com/prod...ers/index.html
What about the Vintage Precision version? It looks like a beast. https://www.ebay.com/itm/Ford-Lincol...c6da%7Ciid%3A1 Then there is this one as well. |
#41 |
The problem with the 2nd type shown above is, as they wear, or encounter a particularly tight hub, they will tend to push off center and bend the shaft or damage the threads. That's what happened to me before I bought the VP one.
#42 |
#43 |
That link took me to Corvette parts.
#44 | |
![]() Quote:
This looks like a nice product |
#45 |
I also have the VP version and have pulled hubs often with it and am very happy with it especially for the price. It's well made and does the job well.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP ![]() Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand ![]() https://www.fordbarn.com/forum/album.php?albumid=580 |
