05-02-2024, 08:17 AM | #1 |
Opinion Re Differential Gear Ratio
My piggy bank state rules-out getting an overdrive unit, so I am considering the installation of a 3.54 gear set. The engine in my Victoria is a Model B with a 6:1 compression head, chopped flywheel & V8 clutch. In your opinion, will my engine have enough power for good cruising with the 3.54 gear set?
Bob Bidonde |
05-02-2024, 08:34 AM | #2 |
Re: Opinion Re Differential Gear Ratio
Absolutely! Been there, done that and pleased with the results.
No restorable Model A's were harmed in the building of this truck! |
05-02-2024, 08:34 AM | #3 |
Yes. I would like to do this to my '31 Victoria. I have many 3.54 gear sets in V8 Fords and even a 3.25 gear.
05-02-2024, 09:28 AM | #4 |
I was happy with the 3.54 in my early 31 CCPU with a stock engine. I am even happier with it since I added a 6.1 Snyder head. Bear in mind though the CCPU is lighter than any other body style.
05-02-2024, 10:01 AM | #5 | |
I just installed my Mitchell O/D in my '31 (stock engine with 5.2 head, stock diff). I entered the queue last May 2023, got "the call" in late December, and took delivery mid-March. I took a long tour on back roads with it last weekend and am very pleased.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
05-02-2024, 10:04 AM | #6 |
05-02-2024, 02:39 PM | #7 |
Bob, I think with the right camshaft and engine package, a 3.27 will be just fine. I have installed both 3.54 and 3.27 gear sets in customer's vehicles. The biggest thing I think that dictates which is better is more about whether it is city or country driving, -and who you are traveling with. If you are in a group of 3 or 4 Model-As that have stock ratios, you generally will find yourself not like a 3.27 simply because you are not in sync with their shift points. If you are by yourself on a rural road, then a 3.27 is a great combination.
Something I want you to think about, ...three of my Model-Ts have a 3.00 rear gear ratio with 30x3.5 rear tires, and my Depot Hack has a 3.25 ratio with 21" tires. All of my engines are basically the same with 6.0 compression ratio, a 280" lift camshaft, an oversized intake manifold and a stock carburetor. Realistic horsepower with my combination is probably in the mid-thirty range. While all of these cars have a Ruckstell (two-speed) rear axle which gives me 4 forward gears vs. a Model-A's 3 gears, I can cruise 48-50 mph all day long in my cars. Those that know me know that I have toured extensively with my cars, -been up to Mt. Rushmore, been up & down the N. England state mountains, all over the Blue Ridge Parkway, Kentucky and W Virginia mountains, and many places in-between. I have never had a mountain that I could not pull. My point is my engine and gearing combination is not unique as there are many others with similar engines and rear ends. If a Model-T with an inch or so larger diameter rear tire can pull a 3.0 Ring & Pinion, then a Model-A with an engine making twice the horsepower and at least 30% more torque should be able to capably pull a 3.27 gear ratio, ...even if it is a Sedan weighing 1,000 pound more. Now before someone suggests that 50mph is different than 60mph, its not that my cars can't do 60, but more about that I run out of brakes & steering in my Ts before I run out of power. I would strongly consider a 3.27 if you are going to touring by yourself, -or with others who have similar gear sets. |
05-02-2024, 06:36 PM | #8 |
I don’t have Brent’s extensive experience but my research aligns with his advice here. An engine with the three core upgrades (head, carb, cam) will run 3.25:1 no problem.
05-03-2024, 08:54 AM | #9 |
Sold this 1800 pound hot rod with 1931 Model A running gear a year ago. Engine put out 60HP at the rear wheels on the dyno during the Speedster Reunion meet. The 3:25 gearing with a '39 transmission left a lot to be desired, so went back to 3:54 gears. I live at 6700' and often times have lunch at a resort that is almost 9,000'. Gear choice has more to do based on where you live/drive and tire diameter.
05-03-2024, 09:14 AM | #10 |
The top mechanic in our club installed a 3.54 in one of his cars because he likes messing with things (as do I LoL). I do not know anything about the motor but I do know that the car already had an overdrive. He liked the 3.54 but it would not work in 3-high so he removed the OD (he has multiple cars and he liked this one to be “a bit different”). I understand the pro’s and con’s involved here and being as I only have the one Model A I would not do it, I would keep the OD (although at the current prices and lead times from Mitchell I might need it elsewhere (if I had another car). From talking to many people, I find that 4.10 and OD make a good pairing with a stock motor. Most people would not know if they liked it or not because have not had an opportunity to try it.
05-03-2024, 09:16 AM | #11 |
I think that 28-29 with 21” wheels vs 30-31 with 19” wheels might make the difference too.
05-03-2024, 09:55 AM | #12 |
I have a Mitchell overdrive with my 3.54. At 45 mph I shift into 3rd over. Everything quiets down and smooths out. I love the combination.
05-03-2024, 10:49 AM | #13 | |
Obviously too much cam will take away low end power, but sometimes just more lift on a modern grind will help. Our 28 A still has the original engine but I have a spare engine I might play with someday! |
05-03-2024, 10:52 AM | #14 |
I have a late 31 coupe with a Mitchell OD and 3.54 gears.Seems to work fine for me.I forget to take it out of OD a lot when I stop,I just drive off again.Very seldom do I get into a situation where I HAVE to take it out OD to drive it.Sometimes I'll have it in OD when I've stopped on a hill,and I do have to yank the lever back to take off.I have no clue what the engine is,I bought the car a few years ago and discovered the 3.54 gears when I went to put the OD in it.I also have a 30 open pickup with 3.54's in it,BF head,B cam,.060 over,zippy little truck.It used to have 3.78 gears and a BW overdrive,that was just a little too tall in that truck.I have never once seen a need to split the gears with the Mitchell in mine.I have another new Mitchell,I wanted to use it in my 28 Phaeton,but it has the early design ring and pinion,not compatible with the Mitchell.
05-03-2024, 11:34 AM | #15 |
I think the Burtz head and cam would be solid recommendations. Carbs are much more about your personal taste. If you want to keep the original profile, converting to a Model B carb and intake is a common choice. After that it's downdraft carbs.
05-03-2024, 12:16 PM | #16 |
I like what Brent said. My 1937 Ford Tudor has a 85 hp V8, 16 in wheels and a 3.25 rear gear. It will drive down the highway very well. I'm in flat land country, no mountains.
05-03-2024, 12:17 PM | #17 |
Thanks all for your comments. Unfortunately, I do not see my piggy bank getting enough to buy a Mitchel OD this year or in the near future. So I will likely opt for the differential gear change.
Considering the 3.27:1 and the 3.54:1 gear sets, at 55 MPH the differences in RPM are 14.5% less for the 3.27 and 6.5% less for the 3.54 gears. At 55 MPH, the motor turns approximately 2357 RPM with the 3.78 stock gears. Thus with a 3.27 gear set at 55 MPH, the RPM should drop 341 RPM to 2016 RPM. If I choose the 3.54 gears, the RPM at 55 MPH will be 2357-153 = 2204 RPM. I will opt for the 3.27:1 gear set, so the search for the gears begins. I live on Long Island which is mostly flat. My annual long distance touring is to the New England Meets which can be a hilly ride. As I mentioned earlier, the engine in my Victoria is a Model B with a 6:1 cylinder head, a chopped flywheel and a V8 clutch. My guess is the this motor has between 50 & 60 HP.
Bob Bidonde |
05-03-2024, 12:33 PM | #18 |
I didn't realize where you lived.From what I remember of Long Island a high gear ratio would be of zero concern.I hauled seed potatoes from there about 40 years ago.I could zip right along with 220 HP pulling 50,000 pounds of seed spuds.Got pretty agonizing once I got off the island and headed for N.H.though.
05-03-2024, 07:14 PM | #19 |
If you need to save $$ just put synthetic oil in it and drive it the rpm might bug you but it won’t hurt the motor (to be clear, I’m talking 55, not 85)
05-03-2024, 07:31 PM | #20 |
Bob, I installed the 3;54 in my RPU and it is an improve ment on level ground. The RPU is the lightest of model A's---but in the hills in WV, my best budddy in his stock 3;78 coupe takes great pleasure in riding my bumper --up hill --and oogahing his damn horn. So I guess it is a mixed blessing. Toodles, JR
05-03-2024, 09:28 PM | #21 | |
The current sets are manufactured by Italian company Motive Gear. I think they must do them as a custom part run because this particular gear set is not listed in their catalog. Either Snyder's or Bert's sells the 3.25 gears for about $525. Sacramento Vintage Ford lists the old-style 3.27 gear set in stock for $750. |
05-03-2024, 10:18 PM | #22 |
On 2 of my cars, I run 5.25X21 tyres on the back and a stock 3,78 rear end. That gives me an effective ratio about the same as running a 3.54 diff (to within 1%). By the time I engage the 26% Mitchell O/D, the effective ratio is 2.81 - way higher than anything spoken about so far. There have been times when I have forgotten to take the car out of O/D when I stop and try to move off in high 1st. It doesn't like it but once moving, I love high 2nd and high 3rd gears. Even towing a trailer that weighs as much as the car, 50 mph on the flat is easy.
The motor has a 5.5 head on it but I'm sure it is higher now that it's been planed a few times. It cranks 105 - 110 psi compression. It has a mildly modified cam and a down draught Stromberg carburettor that has a throat the same as the first barrel of a Webber (26mm) I estimate it puts out about 70 hp. That combination has been all around this continent (same size as your lower 48) a couple of times and more and loves the flat outback country. Around these parts, I don't tow very much and that setup is great for solo car touring. I wouldn't change what I have for versatility. In short, with the right engine, 3.25 should be good ratio but with a less modified one, I wouldn't go higher than 3.54 and be prepared to travel slower. It is worth noting that the engine will be working harder with a high ratio and cooling could then become an issue. Ask the man who knows!
