10-09-2019, 09:47 AM | #1 |
32 Cabriolet repro parts?
Hi,
Does anyone reproduce for 32 Cabriolet: The stainless frames for the door window glass? The pins on top of the windshield that locate and secure the header? Door latch mechanisms? Top kit, now that LB is no more? Anyone have any of these rare bits? Thanks for any assistance. Bill |
10-09-2019, 07:54 PM | #2 |
Re: 32 Cabriolet repro parts?
Heck - all I want is the dang stainless channel that holds the rubber on the A-pillar to window seal. I have one . . . but boy do I need the passenger side! The 32 Cabs are a somewhat rare and unique beast . . . many parts are not common to any other body styles.
10-09-2019, 08:21 PM | #3 |
Have you talked to the Cabriolet Society?
10-09-2019, 08:34 PM | #4 |
Lots of guys may be able to make one by the other. You’d be shocked at how many parts are fabricated on the rarer body styles
Mirror image?? How about post a pic ?? |
10-09-2019, 10:33 PM | #5 |
10-10-2019, 02:14 AM | #6 |
Am too missing the top garnish molding above the screen and the door garnishes. |
10-10-2019, 06:55 AM | #7 |
I didnt know of a cabriolet society for the 32 just the Model A Ford. It would be cool to have one or even start one.
I love the 1932 cabriolet and have a few plus extras parts ,door posts quarter panels etc.. Since they are hard to find parts and for them as well. We made the window frames and a buddy made the tracks and frames as well off originals. I made the garnish moldings off a set of the originals and really are pretty basic. I have yet to find or even see a window to door glass weather seal. Neither of my cars have them and would love to get or make them to make it weather tight. Your door latches are 5w and Tudor just a different length rod . I believe I still have some window channels but built a bit different and better then the originals ..
Wanted flathead speed equipment Thanks |
10-10-2019, 07:08 AM | #8 |
Are the 32 Cabriolet window frames the same as the 33-34? I know the 35 through late 30's are the same but wider than 33-34.
10-10-2019, 07:31 AM | #9 |
The 1932 window frames are just 32 size wise but maybe the same construction and similar window channels
10-10-2019, 07:42 AM | #10 |
Somebody post a picture pls.
10-10-2019, 07:50 AM | #11 |
Easier to say then done, my devices will not load pictures on the fordbarn any longer till today crazy..
Wanted flathead speed equipment Thanks Last edited by hop up; 10-10-2019 at 08:06 AM. |
10-10-2019, 07:56 AM | #12 |
32 cab quarter panel chunk
10-10-2019, 07:57 AM | #13 |
Here are pics of the window trim and rubber from the late Dick Spadaro.
10-10-2019, 08:05 AM | #14 |
Original frame trimmed at the sliders for some reason under the reproduction stainless frame on top
10-10-2019, 08:59 AM | #15 |
The rubber window seal looks the same as the later Ford convertibles (35-48). If they are the same then you can use the channel that is used on the later convertibles. You probably will have to shorten the channel. Had a '32 cabriolet years ago and I recall the channel and rubber came from repo stuff for the later convertibles.
10-10-2019, 09:24 AM | #16 | |
10-10-2019, 06:07 PM | #17 |
Except for very early '32 cabriolets, the stainless channel and rubber on the A pillars is the same as later cabriolets and convertibles as TJ indicates. While I haven't checked lately, both Bob Drake and Dennis Carpenter offered excellent reproductions of both and also offered a fuzzy tape to cover the rubber to duplicate the original surface on the rubber. (Very early cabriolets used a narrower channel and rubber insert; it's all in the book.)
10-30-2019, 07:35 AM | #18 |
Thank you for the info on the rubber weather stripping, I just cant seem to find that info in your great book.
10-30-2019, 10:45 AM | #19 |
Please see page 16-7.
10-30-2019, 10:51 AM | #20 |
I lent my DavidG books to a friend . . . and of course he hasn't brought them back. Does anybody happen to know the width of the two different rubber seal channels for the A-pillars on a 32 Cab? I'd like to determine whether I need an early or late version. Thanks gang!
10-30-2019, 12:40 PM | #21 |
They are 13/16" - early and 1 1/16" - late; both dimensions are the width inside the channel, not the overall width.
10-30-2019, 03:50 PM | #22 |
Thank you DavidG
Wanted flathead speed equipment Thanks Last edited by hop up; 10-30-2019 at 04:08 PM. |
10-30-2019, 11:35 PM | #23 |
Hi; I've got a couple of locals working on '32 cabriolets. I made the little brackets that fit in the doors. Sort of a window guide or stop. A car used two rights and two lefts. No one seems to need any more. they were missing from a couple of local basket case Cabriolets. I can sell them for $5 @. Newc
10-31-2019, 02:55 PM | #24 |
The stainless window channels for 1932/39 are available reproduction from (in the correct size and shape) both Carpenter and Drake and various other parts suppliers.
HOWEVER the rubber that they supply does not fit the channel from my experience and just falls out as it is too narrow. I ordered repro rubbers from The Early Ford in LA and they fit these channels perfectly and even have the correct felt covering. |
10-31-2019, 05:11 PM | #25 |
Thank you for the information Mr Freeman
