08-27-2018, 09:10 AM | #1 |
Oil pump questions
Hello, I have a '39-'41 221c.i. bored to 239. The engine just turned 10,000 on the clock (I assembled the motor). I'm planning to replace the rod bearings (full floaters) and the oil pump, my question is can I use a Melling M-15 pump without any adverse effects? The reason I want to do this is because the engine on start up after sitting for a week or two makes a slight knocking noise. I did not use a new pump when the engine was assembled.
Thanx, Tom |
08-27-2018, 09:44 AM | #2 | |
Re: Oil pump questions
That knock is not going to get better regardless of the pump chosen. When you replace the bearings, I assume you are having the crank (at minimum) polished. Be certain to check clearances carefully at that stage of reassembly. A stock pump is more than adequate for a stock build. More pressure is not necessarily an improvement.
08-27-2018, 09:51 AM | #3 |
There are a lot of folks that prefer the original pump (even used) over a new pump. What is your oil pressure reading?
08-27-2018, 10:38 AM | #4 |
The oil pressure is another issue, on start up the oil pressure is 50+, after running at high speed on the highway the oil pressure is 5 to 8 lbs.(at idle) At speed the oil pressure is 15 to 20 on a hot day.
Tom |
08-27-2018, 10:43 AM | #5 |
08-27-2018, 10:57 AM | #6 |
08-27-2018, 11:10 AM | #7 |
I would think your oil pressures are OK. Make sure your gauges are accurate. I just completely rebuilt my 47 flathead & did not have a stock pump on hand & used a melling19 pump. Oil pressures are a bit higher than I would like but they may come down after it gets a few miles on it.
AS stated above I would be more concerned about the knock. |
08-27-2018, 12:18 PM | #8 |
I would use a stock pump especially on the engines that use the slinger in the rear instead of the rope seal. A higher volume pump will have a tendency to flood the rear main and cause an oil leak in engines using a slinger. One thing I always do when rebuilding one is to have the crankshaft ground to the next undersize and tell my machinist to leave the rear main "full" or on the high side of the measurement . By doing this it eliminates any oil getting pushed out the rear. An old Ford mechanic taught me that 30 years ago and he was 87 then. I still live by it . It works.
08-27-2018, 03:17 PM | #9 |
Would the slight knocking noise be perhaps a bit of piston slap?
08-27-2018, 05:23 PM | #10 |
Thanx for the responses, I'm planning to remove the engine, find the problem and fix it - what ever it takes. And I think i'll use an original pump, does anyone know the end clearances (gears/end plate).
Tom |
08-27-2018, 06:54 PM | #11 |
Its sounds just like my engine and why I decided to build another. I had no problem with that oil pressure over the years for daily to and from work, however high speed running on the freeway never made me feel comfortable I did consider 'cheating' and using a high volume pump..
08-27-2018, 07:28 PM | #12 | |
John |
08-27-2018, 08:02 PM | #13 |
John, I guess my description of the engine starting events was incomplete. When I first start the engine there is a slight light knock, maybe two or three knocks and then the engine has normal operational sounds. That leads me to believe that a rod bearing is making noise until oil pressure reaches that rod journal.
Tom |
08-27-2018, 08:19 PM | #14 |
to find the "leak"---loose bearing you need a pressure pot to fill the oil gallerys, any bearing that has more than a drip is loose ---this way you know all the losses to your oil pressure
08-28-2018, 09:15 AM | #15 |
Kurt, and everyone else who has responded with info and suggestions, thank you. I have resigned myself that the engine is going to come out and be disassembled. I'm thinking about using a "59" crank and "8ba" rods with insert bearings. Any pros and cons.
Tom |
08-28-2018, 09:26 AM | #16 |
hotcoupe--A 59a crank & 8ba rods is not a good combo.
The 59a crank has a single oil hole per rod journal, for full floating bearings. 8ba rods require 2 oil holes per journal for correct oiling with the insert bearings. Use an 8ba crank with the 8ba rods. Last edited by 42merc; 08-28-2018 at 09:37 AM. |
08-28-2018, 09:31 AM | #17 |
42 Merc, I mis identified the crank as a "59". This crank has two oil holes on the rod journal. Would you recommend an insert motor over a full floater?
Tom |
08-28-2018, 09:57 AM | #18 |
Full floater gets my vote.
08-28-2018, 10:03 AM | #19 |
hotcoupe--Insert bearings are so much more user friendly plus they are more available & less expensive.
The oil holes on your crank, are they side by side, about an inch apart ? |
08-28-2018, 10:29 AM | #20 |
42 Merc, yes the holes in the rod journal are side by side approx. one inch apart.
Tom |
08-28-2018, 10:37 AM | #21 |
Ken, Why do you prefer the floater over the insert?
Tom |
08-28-2018, 11:29 AM | #22 |
That's the way to go.
08-28-2018, 11:58 AM | #23 |
If floating bearings are so good, why has no manufacturer used them since 1948 ?
08-28-2018, 06:28 PM | #24 |
Expense
08-28-2018, 09:27 PM | #25 |
08-28-2018, 10:07 PM | #26 |
08-29-2018, 07:54 AM | #27 |
The full floaters are a good setup. They are time consuming & need properly re-conditioned crank & rods plus some math skills to implement.
I personally have not done any in over 10 years. |
08-29-2018, 03:15 PM | #28 |
Be sure the cam bearings are a good fit, you can lose a lot of oil pressure right there.
