#1 |
ModelACarMan and I are trying to figure out how to post pictures on Ford Barn. Can anyone give a hand?
Marty |
#2 |
I'm not an expert but I use the paper clip function, then add pictures. I ran into problems with very large files not being accepted
#3 |
#4 |
Easy way for pics:
Click the "blue post reply" lower left bottom of page, when text box opens, in the top middle of the bar you will see a "paperclip" click that, a window will open "manage attachments" click "choose file" then pick your picture, after you picked up to seven pics click the top "upload" on the right hand side of the text box, wait for it to upload. You must type something, anything into the text box message, scroll down to see "preview post" at bottom of your text box, you should see your message as it will appear when you post, if you like it click "submit reply" to post. Easy-cheesy
#5 |
Works every time
#6 |
There you go Bob. Try that! |
#7 | |
![]() Quote:
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? ![]() |
#8 | |
![]() Quote:
Posting Pictures does not work for me any more. There is some thing wrong with the Ford Barn site. I can post pictures anywhere else, like I have always done, with no problems. This started for me when to Ford Barn was changing some of there program. Herm. |
#9 |
I have to leave for work right now, I'll find you a way and get back
#10 | |
![]() Quote:
If you hover the mouse pointer over the top paperclip, it will say "Attachments" where the lower one with the planet Earth will say "Insert Link". You want the "Attachments" one in the top row. |
#11 |
This is the sign I get !
Your submission could not be processed because a security token was missing If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received this error. I informed the administrator 3 times, and what they said for me to try, does no good. Herm. |
#12 |
#13 |
Maybe you need to sign out and then sign back in.
I'll try another picture. Ever wonder where I got my screen name? Randy I click on "go Advanced" Enter text Go to "Manage attachments" choose file Select Upload
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
#14 |
Your picture file must meet all the size requirements for your file format. Those requirements are stated in the attachments window.
I don't know why after years of this question coming up Ryan doesn't put simple instructions in a sticky at the top.
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. ![]() |
#15 |
Another work around.
Go to this site http://tinypic.com/ Browse to your jpg picture and click upload now. Make sure your picture file is resized to small file size first. Then enter the code, it will convert it to HTML, URL, or IMG. Copy the URL or IMG and then in the forum click on the icon that says insert image and paste it in. This will usually work with either URL or IMG depending on the forum.
68B frame# late May1930, fixed seat, Briggs build plate# & most parts, indicate July, or early Aug. 1930. Last edited by kimeccles; 03-24-2018 at 07:41 AM. |
#16 | |
![]() Quote:
Yup, exactly as mine does now ! I've not done anything different than what I've done for years, when posting pictures worked for me. Posting pictures makes a 'story' a lot simpler/clearer when trying to explain and/or help with someone's inquiry or with my questions. YOUR pictures have helped many here and they will be missed. |
#17 | |
![]() Quote:
I've tried to duplicate your problem but can't get what you are getting.
#18 |
I have been posting pictures the past two weeks using the method I described above with no problem.
68B frame# late May1930, fixed seat, Briggs build plate# & most parts, indicate July, or early Aug. 1930. |
#19 |
I have posted many years on here, why the change now !
#20 |
Since something changed a month or so back, I can't post the icons, but can post pictures the same way I always did.
Click "Go Advanced", then scroll down to "Manage Attachments" Then click "Browse" and find the picture in "My Pictures" in my computer Then click on the picture and "Upload" |
#21 | |
![]() Quote:
This is definitely NOT the way to post pictures. Tinypic is owned by Photobucket. Photobucket was responsible for thousands of pictures in thousands of threads on dozens of forums, etc. being deleted from any account that didn't meet their $400 per year ransom request. If you're not familiar with this happening do a search either here on Fordbarn or on the Internet - there are many very upset former Photobucket users as well as many upset forum users. What happened with Photobucket (or many other things) could easily happen with any photo hosting site including Tinypic. Load the pictures into Fordbarn and they'll likely be around as long as Fordbarn itself is. |
#22 |
Here is some help;
https://www.fordbarn.com/are-ya-lost/posting-images/ From Tom; 1. Click on "Go Advanced" 2. Click on the "Paperclip" 3. Click on "Browse" 4. Find your pictures and click on "Open" 5. Clcik on "Upload" and wait for the pictures to finish uploading. 6. Come back to the message box and finish your message or click on "Submit Reply" Here is another one; https://www.fordbarn.com/forum/showthread.php?t=166143
#23 |
Thanks, I will do it right from now on.
#24 |
It has been a couple of weeks and I am still waiting to hear what kind of software and hardware you are using.
Charlie Stephens |
#25 |
If to a posting or replying at the bottom click on "Go Advanced", there is a "Manage Attachments" to attach Pictures/documents into your post/reply.
Another method is to use Snippet, which is a program most have standard in their computer you use your curser to outline what you want, it grabs it and you can ter it into wherever you want. If interested goiogle snippet, create a shor cut to your desktop. Limitatio0n is it works only on what is display, does not do multiple pages. |
