02-21-2015, 10:48 AM | #1 |
Head Studs
Had too change head gasket in my 31,found head studs not screwed down too the shoulder of the stud,some were quite loose in the hole.Should these be screwed in tight ? This was a fresh rebuild,mabey wanted to keep all studs same height ?Thanks fer the help !
02-21-2015, 06:13 PM | #2 | |
Re: Head Studs
Studs should be screwed all the way in to their shoulder and screwed snug but not tight. There should be no problem with the height of the studs if they are original or a correctly made repo. |
02-21-2015, 07:28 PM | #3 | |
Re: Head Studs
In the cylinder business we put them in until they were the right length. With long tie rods you did have to allow for stretch in the rods. They had to be thread in at least 1 1/2 there dia. as a general rule, but that depends on type of material and a lot of other things. We made cylinders up to 24" bore, and they were high pressure hydraulic cylinders. |
02-21-2015, 07:44 PM | #4 |
Re: Head Studs
If you look closely at a cylinder block, you will notice a chamfer about 45 degrees on each stud hole (stock block, not surfaced). Each stud has a corresponding chamfer. Studs should be installed snug (some recommend 5-10 # torque).
In this fashion, no cocking of the studs will occur, thus, no difficulty in head removal. If the block has been surfaced for whatevewr reason, each hole should again be chamfered. |
02-21-2015, 11:38 PM | #5 | |
Re: Head Studs
If you'll read what I said, I did not say tight. I said snug. Snug, by my definition, is just a little tighter than finger tight but not tight as in turned tight with a big wrench. Plus, if the studs are straight there's no reason for them to cock. The bottom end of the Model A stud that screws into the block is made to a length of 3/4". The stud should be screwed all the way in to utilize the full strength of the 3/4 inch worth of threads in the block, as designed by Ford. The original stud length of 3 1/2" for 11 studs, 3 11/16" for the ignition stud (on most Model A's) and 5 3/4" for the long front two are all the correct length so when screwed in to the shoulder, the height is correct to accommodate the thickness of the original gasket and the thickness of the original cylinder head plus the thickness of the original nut, with a little left over to protrude above the nut. |
02-22-2015, 08:51 AM | #6 | |
Re: Head Studs
What ever you say, but they should be put in to the proper length. If you check some of the studs to day I think you will find they are a little short. |
02-22-2015, 09:10 AM | #7 |
Re: Head Studs
I have seen it many times. Some one re taps the treads in the block. You have lets say .002 clearance. You screw the stud in tight, it cocks the stud when it runs out of thread .002 at one 1/2 ". So lets say the stud is above the block 3" that means the top of the stud is off .012 or those who do not know just about a 1/64. Now do the rest of the studs they are leaning ever direction. You will end up with the tops of the studs off .024 you will have to force the gasket and head on. There is no reason the screw them in any more than they were designed for. But do them any way you please. It is your car. |
02-22-2015, 09:19 AM | #8 |
Re: Head Studs
Based on your comment, the stud holes are tapped into the water jacket, correct?
02-22-2015, 09:30 AM | #9 |
Re: Head Studs
George ,
I agree with you on them. I have put onany but i think that guys like herm konke , james , and rich falucca and j &m could shed more experience on it than most of us . I put a head I yesterday and have one stud nut with a few threads left without stud . I wish i had screwd it back out a thread ir two . I have done them both ways and have never had a problem I do think with them in hand tight you will probably never have a hard time getting them out if need be . Not so sure if tighter . Some folks just have a tendency to argue. When you think about it compared to the later 8ba flatheads which had bolts its the tension of the threads to bolt to torque that are critical . The bolt never bottoms out Larry Shepard |
02-22-2015, 09:54 AM | #10 |
Re: Head Studs
The joint of the cylinder head to the block is in tension. Therefore the strength of each stud-to-block connection is determined by the number of threads engaged. Tightness of the studs in the block is not a concern because the cylinder head nuts when torqued will develop the a preload.
Bob Bidonde |
02-22-2015, 09:56 AM | #11 |
Re: Head Studs
Thanks for the input,now just have too decide which way to go !
02-22-2015, 10:03 AM | #12 |
Re: Head Studs
There is no such thing as "correct" head studs and running them down to the shoulder WILL make them different heights. This is particularly true if any of the holes have been drilled in or had thread replacement.
02-22-2015, 10:04 AM | #13 |
Re: Head Studs
Listen to George. My suggestion would be to use some permatex #2 and thread them in to 2 3/4" and let them sit overnight to tighten and put the head on. The #8 stud can be put in to the bottom and the front 2 that hold the water outlet are down snug.
02-22-2015, 01:40 PM | #14 |
Re: Head Studs
02-22-2015, 01:59 PM | #15 | |
Re: Head Studs
I see your point. But that does not apply to blocks that have not had hardware store taps screwed into them or blocks that still have good holes and threads. In addition, many of the repo studs available from the vendors are often not completely straight. Just roll them across a flat table and watch them. The reason many are slightly bent is they are warped by the heat treatment process they receive. They are literally shoveled in. to the oven. I have a fixture that I use to straighten them. Some people will bump them with hammers with them screwed into the block. That method makes me nervous. Now if a person wants guaranteed straight studs then buy some for ARP. They are straightened and threaded AFTER they are heat treated. |
02-22-2015, 02:07 PM | #16 |
Re: Head Studs
Sorry, that's not true. If the studs are original or are made to Henry's original specs and the holes and threads are unmolested, studs of the same length will be the same height above the block after being screwed in to utilize the 3/4" length of threaded area at the base of the stud.
02-22-2015, 02:09 PM | #17 |
Re: Head Studs
That is what I use.
02-22-2015, 03:04 PM | #18 | |
Re: Head Studs
With studs not screwed all the way in, I have seen studs turn slightly with the nut when torqueing to the final amounts. ARP recommends finger tight on their instructions for studs used with flat heads. I like to put a tiny bit extra with a pair of pliers gripping a rag around the base of the stud (with emphasis on the word tiny). |
02-22-2015, 07:11 PM | #19 |
Re: Head Studs
My dad build Model A's and flatheads all his career and the engines for our cars we used Chevy main bolts for my B and sure is nice. I don't have to mess with the studs and the heads come off nice. Doesn't work if your showing the car but for drivers it looks nice.
02-22-2015, 10:22 PM | #20 | |
Re: Head Studs
02-22-2015, 10:30 PM | #21 |
Re: Head Studs
I ran an aluminum head that required longer studs. I made an investment in ARP studs that are about a 1/4" longer than stock. This made up for the extra length I needed due to needing to use washers with my heads. Hearing guys saying to adjust the length of the stud by backing it out of the hole is just stupid. It only has 3/4" engagement to begin with. A benefit of using good studs is I have yet to have a head nut move during retorque of the head. They are expensive, but well worth it.
1927 T, 1930 A coupe, 1929 A Roadster, 1933 Dodge pickup, 1935 5 window coupe |
02-23-2015, 12:05 AM | #22 | |
Re: Head Studs
"There is no such thing as "correct" head studs and running them down to the shoulder WILL make them different heights. This is particularly true if any of the holes have been drilled in or had thread replacement." Bratton's advertises correct length studs. However, judging by the pictures on their site they are the correct length but are still not made correctly in the shoulder area like Ford's original. Ford made the short unthreaded area, or shoulder, at the base of the stud, above the 3/4" threaded area, a full 7/16 inch diameter. |
02-23-2015, 12:18 AM | #23 |
Re: Head Studs
That's exactly Lowbuckboz. Plus look how weak the hole threads may be when a common hardware store tap of the wrong class fit has been run through the hole and cut off good metal.
02-23-2015, 12:49 AM | #24 | |
Re: Head Studs
02-23-2015, 06:07 AM | #25 | |
Re: Head Studs
02-23-2015, 07:44 AM | #26 | |
Re: Head Studs
__________________________________________________ ___________________________ That is not a nice thing to say. I worked with this kind of thing all my life. Last edited by George Miller; 02-23-2015 at 11:58 AM. |
02-23-2015, 08:59 AM | #27 |
Re: Head Studs
Then you know how bad of an idea it is to back the stud out. It will cause lifted threads and head gasket retention issues.
02-23-2015, 09:39 AM | #28 |
Re: Head Studs
Did not mean to start a war with this post,but as long as you have 1 to 1.5 times dia. thread engagement it will hold what the stud will as per machinery handbook .
02-23-2015, 09:57 AM | #29 |
Re: Head Studs
Excuse my lack of knowledge but what is ARP?
02-23-2015, 10:00 AM | #30 |
Re: Head Studs
02-23-2015, 11:47 AM | #31 | |
Re: Head Studs
This will be my last post, at least for a while. I think I have made more threads than you have seen. Have single pointed threads on a lathe, cut threads with a die, rolled threads with a thread rolling head, bump rolled threads. We are only talking about a thread or two in the block, plus the threads on the stud my have been made to long. But it is better to be short a thread in the block than two threads in the nut. Of the engines I have done, I have never seen a stud pull out of the block unless some one tried to get a broken stud out and made a mess of it. Or re tapped the hole with the wrong class tap. You might not know what that means. Different class fit each other with less or more clearance. Fords class on the A has a slight resistance when screw together. You might not notice it. Bye Have worked on many Model A,s redone 25 for my self. I do not like the word restore, that is for cars like Marco T has. Truly like factory. Last edited by George Miller; 02-23-2015 at 02:25 PM. |
02-23-2015, 01:22 PM | #32 | |
Re: Head Studs
"There is no such thing as "correct" head studs and running them down to the shoulder WILL make them different heights." That statement is not true. I have original studs in two of my engines and on one engine I have studs that I bought from a head manufacturer and they are made correctly. |
02-23-2015, 02:56 PM | #33 |
Re: Head Studs
That's the standard rule but in the case of old blocks that have been used multiple times, the strength of the iron that the threads are cut into may be an unknown so it's best to use the length as designed by Ford which is 3/4".
02-23-2015, 05:29 PM | #34 | |
Re: Head Studs
I know, you forgot more than I know. Very bad assumption on your part. Don't get uptight over a conversation. I have seen what I speak of.
02-24-2015, 04:43 PM | #35 |
Re: Head Studs
I have always tightened the studs down, with about a 10 pound torque, 48 years worth.
I use Indian head, or Permatex 300 on the stud at the bottom, as well as all gaskets. Our engines always get the stud holes cleaned out. If you don't you can't get a truely clean hole, with rust, old gasket cement, ect., and you cant see any thread damage clearly. Molested holes have been talked about, but we fix those kind. Also we can be trusted around studs, Dogs, and little Children. Yes the studs are out of alignment a few thousandths on what I find to always be 1 to maybe 5., we NEVER use old studs on A's, or B's. I use the head gasket to align the studs. First when you lay the gasket on, it looks like their all bent, but I have found this not to be the case. Always take the worst one first, but don't do a 100% job, but look for another off one, and that most of the time will let the gasket drop like a rock. If the gasket drops, so will the head. I have a 3 pound lead hammer I tap them with, DO NOT POUND, but tap. The point of tapping is the bottom of the threads, on the top of the studs. In my opinion, the studs should be locked on the shoulder, "THAT PULLS THE THREADS TIGHT", as loose threads would have to stand all the torque. Also if there is water leakage, you would just have another place for water to come out of, that is not sealed. Lastly, in all the other makes of cars, tractors, ect., I have NEVER seen any body leave a stut bolt loose! Those that are worried about a short stud, just replace it with another one. After Vern at Arnold Motors, In Fort Dodge, Iowa gets any bad holes fixed, and surface, I just don't have trouble with stud bolt height. In any engine, block, body, running gears ect. Herm. Last edited by Kohnke Rebabbitting; 02-24-2015 at 05:00 PM. |
