02-20-2015, 08:18 PM | #1 |
Counterweights vs Balancing Heads Up
Looking closely at postings and blogs it has become very clear that there is a lot of confusion/misunderstanding of what these two terms really mean.
'31 180A Last edited by tbirdtbird; 02-03-2017 at 10:28 AM. |
02-20-2015, 08:53 PM | #2 |
Re: Counterweights vs Balancing Heads Up
Tbird, great post, thank you.
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
02-20-2015, 09:14 PM | #3 |
My 29 tudor has a 1936 diamond block engine. Since counterbalanced cranks were introduced in 1932, would my 1936 diamond block have a counterbalanced crank?
02-20-2015, 09:25 PM | #4 |
I doubt it. None of the diamond block A engines have had a counterbalanced crank in them. Other than the B cranks that had larger journals, Ford did not make a counterbalanced cranks cor this era of four cyl's. Rod
02-20-2015, 10:26 PM | #5 |
Even a Model T crank can be balanced. Simply means that the weight on both side of center are the same. A good balance job includes the flywheel, crank, presure plate and pulley for people not using counter balanced crank. Also rods and pistons within a few grams of each other. While this would not get rid of vibration like a counter weighted crank might, it should help a lot.
02-20-2015, 11:14 PM | #6 | |
After the second paragraph, most of the info is wrong or partially wrong. I'm not going to elaborate on the details because all of the correct information on balancing automotive engines is covered by numerous articles all over the internet. |
02-21-2015, 12:38 AM | #7 |
so give us your version
a lot of the info was lifted from the Scat and Eagle websites
'31 180A |
02-21-2015, 01:01 AM | #8 |
"I'm not going to elaborate on the details because all of the correct information on balancing automotive engines is covered by numerous articles all over the internet."
02-21-2015, 01:23 AM | #9 |
My 29 with a dead stock, never been apart motor is smoother and quieter than my 31 with a balanced, inserted, counterweighted crank touring rebuild. Admittedly, the rebuilt motor has more power. The motor that has never been apart runs fantastic. The rebuilt is strong and torquey, but will vibrate your glasses right off our face. That car is developing new rattles all the time.
02-21-2015, 01:28 AM | #10 |
No amount of crankshaft counterweighting or flywheel weight manipulating can eliminate the primary imbalance of an I-4 engine. The primary imbalance is caused by unequal forces and piston velocities between upstrokes and downstrokes. Only weights mounted on a separate counter rotating shaft can cancel most of this and a give real seat-of-the-pants improvement. The problem is exacerbated by the A engine design, with exceptionally long rods and a stroke exceeding the bore.
Counterweights serve only to reduce crank main bearing radial loading. Anyone who feels "seat of the pants" improvement from a counterweighted crank and/or change of flywheel momentum (a bit more complicated than 'weight') is only seeing an improvement compared to a less-than-factory rebuild. There are definite engine life benefits to a counterweighted crank and sufficient dampened external rotational mass at both ends of the crank to reduce torsional harmonics, but you will not feel it compared to an engine that came off the line at the Rouge balanced to Henry's specs. |
02-21-2015, 03:47 AM | #11 |
I have used a 12 lbs aluminium flywheel on a stock but well mechanically balanced
and still have all my teeth in my head that is to say it had no more vibration then engines with a heavy flywheel the counter weighed cranks that we commonly see are NOT counterbalanced cranks they have only a small % of the weight need to counted the throw weight just do the math the only ones that even come within a bulls roar are Dans when added to a good mechanical balancing Mikes is correct inline 4 have lots of problems with balancing let us not mention thing such as the added weight of 3 of the 4 strokes in our 4 stroke engines and negative weight on the other stroke this effect increases as compression gets higher 1 reason a stock low comp engine is smoother or the effect of big ends plunging into a trough of oil at the bottom of the stroke IMO if we want smoother and more power full engines we would be better off with a 2up 2down crank and a harmonic balancer |
02-21-2015, 05:03 AM | #12 |
Great post and now I can better better understand why Henry used the heavy flywheel, guess I am very lucky because both my 31s have very little vibration, actually my Roadster is smooth as silk .
Chuck McDonald, Member of AACA, Model A Club, NRA Last edited by inex01; 02-21-2015 at 05:10 AM. |
02-21-2015, 08:27 AM | #13 |
The use of a heavy flywheel is an inexpensive way of damping the vibrations of the Model A engine. However, that heavy flywheel is mechanically inefficient because:
>It requires considerable torque to accelerated / decelerate it; >It places high stresses in the rear main bearing; >It increases the twisting stress (torsional shear stress) in the crankshaft; >It makes the rear engine mounts the pivot in a seesaw which lead to the inefficient design of the front engine mount.
Bob Bidonde |
02-21-2015, 09:19 AM | #14 | |
Joe K
Shudda kept the horse. |
02-21-2015, 10:44 AM | #15 |
Location: 40 Mt.Vickery Rd. Southborough,MA 508-460-0733
A statement was made that a stock A crank (meaning with no counterweights) could be 'balanced better than Henry did in in 1928'. This is very misleading, since there are no counterweights present to offset the weight of the pistons and rods. If A modern day flywheel (say 25 lbs) were used on a stock A crank the engine would vibrate itself to death in short order and your teeth would jar out of your head in less than a mile.
So, Henry made the flywheel a massive 62 pounds. This reduced, but did not eliminate vibration. Anyone who has ever driven a stock A can attest to this. This statement isn't entirely true. Due to the fact that: balancing machines have improved and we can now balance a rotating assembly better than henry did in 1928. We are not working to Ford factory spec as they balanced everything to approximately 6 grams. We are now balancing parts to less than .2 tenths of a gram. Balancing is one part the harmonics of the engine are another as "MikeK" pointed out. We have balanced many engines and stock versus counterweighted, naturally the counterweights do add to the dampening effect. However for the customers who don't want to spend the extra money for the counterweighted cranks the engines run well since they are balanced. If you look close at the two printout sheets you'll notice what the unbalance was for the crankshaft and the pressure plate/flywheel. Flywheel started out a 71 grams.! Now it's balanced to .3 grams at 4000 rpm. Same applies to the crankshaft now final balanced to under a tenth of a gram. If the machine shop does a good job balancing the engine the vibration "Harmonic" is moved to a higher plane that the rpm's of the engine won't be able to reach. Therefore the engine runs smooth for what it's designed to do. http://www.jandm-machine.com/balancing.html |
02-21-2015, 11:14 AM | #16 |
While I lack the background to contribute anything of technical value, I do want to say I am enjoying the post and the back and forth. At a minimum, this is helping me figure out some of the right questions to ask and options to consider. Thanks all!
02-21-2015, 12:35 PM | #17 | |
If it is as bad as you say, then something was over looked. Herm. |
02-21-2015, 12:41 PM | #18 |
Revisiting this thread from awhile ago may be of some interest.....
https://www.fordbarn.com/forum/showthread.php?t=89197 . |
02-21-2015, 01:16 PM | #19 |
As far as the cranks go, all the motors I have bought or built in the 1932-34 engines. the crank styles were.
1. crank with no weights. 2. Cranks with weights, as part of the crank. 3. Crank with weights shrunk on like we made for 38 years. In that order of manufactuer. This is one of our A cranks, 5/8's wide. and no need for the wider part of the weight unless your hauling a load of corn in your truck. We don't build these cranks now, as we don't have time. One last thing, these cranks came out in almost perfect balance, before balancing. Herm. |
02-21-2015, 02:09 PM | #20 |
For those who are interested, Ford's precision on the Model A was as follows:
Connecting rods balanced to within 2 grams. Total weight held to within 4 grams of limit. Pistons were matched within 2 grams. Total weight held to within 4 grams of limit. Piston assemblies matched in weight within a limit of 3.5 grams. Piston pin and pin hole diameter held to within .0003 of an inch. Crankshaft was balanced dynamically to within 4 grams. Main and connecting rod bearings were held to .00025 of an inch of true roundness. Crankshaft bearing alignment in the block was held to within .0005 of an inch of absolute true. |
02-21-2015, 02:36 PM | #21 |
Now, regardless of Ford's brag and balancing statements, etc. in my post above, anybody with any experience knows that the A crank, as Henry made it, has a strong tendency to whip, both at the center and at the ends.
If you study the distribution of weight masses on an original A shaft, you will quickly see that although the thing is basically in balance statically, it is far out of balance when in motion. The centrifugal forces developed by the unbalanced weights of the circular throws tend to pull the center of the shaft in one direction and at the same time pull the ends of the shaft in the opposite direction. Also, the bolting on of the connecting rods compound the imbalance. The result of this is vibration and bearing wear. Before I knew better I used to wonder why the center main always seemed to be worn out. Counterweights will minimize this whipping effect and reduce vibration. Try it and you'll see. |
02-21-2015, 03:07 PM | #22 |
You can "balance" a inline 4 motor to only a certain point.
The most of the "felt/perceived" in-balance is the non-symmetrical acceleration of the pistons at top and bottom of stroke. Long stroke and big piston is largest contributor along with speed of operation. J |
02-21-2015, 03:45 PM | #23 | |
The heavier the flywheel the smoother the idle, the easier it is to move the car from a dead stop and any slight throttle changes are smoother. Also, the energy of a heavier flywheel, once in motion, was considered back in the day to be a plus for moving the Model A through soft dirt, etc. while in lower gear at slow speed. BUT .... once the heavy flywheel energy is used up, the engine has to provide more power to keep the extra weight spinning and the extra weight, as compared to a lighter flywheel, becomes an opposing force. |
02-21-2015, 03:58 PM | #24 | |
If you don't mind me asking, where are you getting these numbers above? Maybe you have better resources than I, but quite honestly, my prints for A-6200-A rods, A-6110-BR & CR pistons, A-6325 Main Cap, etc. are showing different specs than what you are stating. Maybe you are saying some of this in a different manner however using the connecting rod as an example, I did not see anything regarding 4 grams. It simply shows that all rods must be 198 ± 1 gram on the wrist pin end, and 525 ± 1 gram on the babbitted end. I guess my thought is the maximum amount of possible difference is 2 grams (1 gram for each end). By you stating there could be a variation of 4 grams would indicate that a rod was out of specification. You also mentioned the piston pin to hole clearance was three ten-thousandths, yet on the print it stated the ± was .9995 - 1.000. On my crankshaft print, it says "SHAFT MUST BE IN BALANCE DYNAMICALLY WITHIN .3 OUNCE INCH AT ANY ONE POINT OF REFERENCE". It also states on the print that it must be statically balanced within .3 ounce inch too. It speaks of axes (axis??) specs of the rod journal pins in relation to the main journal pins, and it speaks about runout of flanges, pilot holes, and crank gear shoulders, but nowhere that I can see on the print does it mention the word "grams". Where are you finding this? The same thing with the main cap. It gives a specification however it is much greater than what you have indicated. TIA. |
02-21-2015, 04:08 PM | #25 | |
Likely True, and for smooth power: Wankel engine
02-21-2015, 04:28 PM | #26 | |
The weight of the flywheel is what takes its toll on the center main, as the crank runs bowed in the middle. The heaver the flywheel, the heavier and more pressure the bow. Model T cranks are the opposite, the flywheel is supported on both sides of it with 2 bearings, rear main and the ball cap, so the front and center don't wear near as much an the rear main which carries most of the weight because it is closer. Model T cranks will may be wore 3 to 6 thousandths on the front and middle, where the rear can be wore .030 thousandths. Where as a Model A will be wore .003 to .006 thousandths on the front and rear main, and the middle wore .020. Herm. |
02-21-2015, 04:48 PM | #27 | |
Ford Dealer and Service Field The Acme of Precision |
02-21-2015, 04:53 PM | #28 |
You also mentioned the piston pin to hole clearance was three ten-thousandths, yet on the print it stated the ± was .9995 - 1.000. "END QUOTE"
That is not right as 1.000 is an inch, don't ya think it would make some kind of a little noise! I think that is your wrist pin O.D. I know that wrist pin clearance should be .0003, to .0005, no more, and or no less, and .001-00 would also be already wore out. |
02-21-2015, 04:54 PM | #29 |
02-21-2015, 05:05 PM | #30 | |
Yes, the hole diameter was held to within .0003 clearance over the pin O.D. Last edited by edmondclinton; 02-22-2015 at 12:00 AM. Reason: Didn't need the word "diameter" after O.D. |
02-21-2015, 08:43 PM | #31 |
Except for Pete, the consensus has been that counterweights are beneficial, with partial or full endorsement.
Put another way, if they were not beneficial, why would all modern day cranks (since the '40s) have them?
'31 180A |
02-21-2015, 09:26 PM | #32 |
Statement by tbirdtbird.
"If A modern day flywheel (say 25 lbs) were used on a stock A crank the engine would vibrate itself to death in short order and your teeth would jar out of your head in less than a mile." Since you seem to be having trouble understanding basic engine design, I will give you some examples of what has been going on in the past and present. Back in the 30's when model A and B engines were popular in sprint cars (called big cars in those days) they ran no flywheel at all. Most real race cars of today (not vintage class) run no flywheel. The crank is connected direct to the u-joint. The race engines of the 30's did not vibrate any more than a stock model A right out of the factory door. I build vintage circle track engines and the ones that get flywheels use an 11 lb 350 Chev V8 flywheel. They sure don't shake your teeth out and they turn 6000 rpm. As far as getting rid of the felt vibration in an A/B engine, as others have said, it can't be done without redesigning the engine. You can not get enough counterweight on the crank. I took a BB crank one time and cross drilled the weights and put heavy metal in the holes. It did reduce the vibration slightly but the engine was quite sluggish coming off the corners due to the added weight on the crank besides the BB crank being much heavier in the first place. |
02-21-2015, 09:34 PM | #33 |
Bill Stipe, throw those cranks away!!!
'31 180A |
02-21-2015, 09:45 PM | #34 |
02-21-2015, 10:35 PM | #35 |
I hope peoples panties aren't getting in a pucker over what tbirdtbird was trying to explain. Yes, engines should be balanced as well as possible. Beyond balancing, the rotational pulses are what people perceive as "imbalance". They try to twist the motor. I have one of the smoothest Ford 4 cyl engines that I have ever seen. It is not in my Model A but I have thought about putting it in one. It has a counter weighted crank. It has a separate counter balance shaft that turns opposite the crank. The cylinders form a "V", 2 on each side. It was made by Ford in Europe and used in '60's Saabs. Ron W
02-21-2015, 11:57 PM | #36 |
