04-13-2014, 08:51 AM | #1 |
12 volt coil on a 6 volt engine
Hello,
My 6 volt coil failed and I just have a 12 volt coil to run tomorrow morning. What do you think about that ? Does it work ? Very well ? Limits ? Thank you |
04-13-2014, 08:58 AM | #2 |
Re: 12 volt coil on a 6 volt engine
You should a ballist resster in line to reduce voltage
04-13-2014, 09:05 AM | #3 |
No extra ballest resistor needed. It will work but will have a lower output voltage to plugs, engine may not run as well, but if you have do not have a 6 volt coil it is worth trying.
Jon "If you choose to not decide, you still have made a choice!" RUSH Don't tell me what you know..... Tell me what you have done. |
04-13-2014, 09:35 AM | #4 |
I think that's the other way around. Using a 6v coil on a 12v battery requires a resistor - a lot of 12v coils include a resistor (put there to prevent burning up the coil should the engine stop with the points "on.") but many don't.
I say just do it. Otherwise known as "nike-it." If it works - it works. If not you can't hurt much. Joe K
Shudda kept the horse. |
04-13-2014, 09:42 AM | #5 | |
Can you measure the resistance with an ohm meter across the the 2 coil posts? Some "12 volt coils" read out at about 1.5 ohms and require an external ballast resistor to be able to use them on a 12 volt car. You can run a 1.5 ohm "12 volt coil" on a 6 volt car without a ballast resistor and it will run great. Some "12 volt coils" read out at about 3 ohms and can really only be used on a 12 volt car. The spark out of this "12 volt coil" when used on a 6 volt car will be very weak. The car might start but you won't like how it runs with the weak spark. If you have a NAPA near you, you can get an IC-12 coil for your 6 volt car that will be around 1.5 ohms. Lots of confusion around coils and volts. I hope this helps.
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" |
04-13-2014, 11:23 AM | #6 |
I don't have an ohm meter. My 12 volt coil ( not damaged ) is propably 50 years old. Perhaps, last chance : I'll try to call an old man who owns old cars. |
04-13-2014, 11:40 AM | #7 | |
Yeah. I know. They're offshore sourced. And they're not that accurate. And they're not that well made. But FREE is FREE. At least until the end of the month of April - or while supplies last. See attachment below Joe K
04-13-2014, 11:42 AM | #8 |
Shame on me !
04-13-2014, 12:21 PM | #9 |
Many [ but not all] internally ballasted coils will have markings as such on the outside.
Your 12v coil should work fine if not internally resisted. Once you get ahold of a volt meter, regardless of 6 or 12 volt systems you only want 6-8 volts feeding the points. |
04-13-2014, 03:39 PM | #10 | |
Just use it! It will cause no harm. It might just run poorly. You'll know soon enough.
04-13-2014, 03:55 PM | #11 |
I agree with Jim. How many old cars (12v) had an external resistor.
04-13-2014, 05:11 PM | #12 | |
Most. Chrysler mainly with their famous external ballast resistor, Ford had it both ways as did GM using either a mounted resistor as Chrysler, a resistor wire or resistor coil. Some coils were noted as such but not all. Many folks then were not aware of the resistor wire. |
04-13-2014, 05:24 PM | #13 | |
04-14-2014, 10:37 AM | #14 |
I've run any number of 12v coils on 6 volts. They always worked fine. A guy has to learn how to do things like that if you want to save yerself in a squeeze. 50+ years ago, we didn't have money for a new coil. We had to make do. Go for it!
04-14-2014, 12:17 PM | #15 | |
Like Joe said... I would get a meter and measure it to know what you have... it should be between 1.2 and 1.5 ohms. If it is it should be fine. I gave a voltmeter and troubleshooting seminar at the MARC Membership national. All the guys in our group picked up the free meters from Harbor Freight when they could, so everyone attending the seminar went home with a free meter from the seminar. They are not the best, but will get the job done. Again, get a meter and check it ( all wires off) and see what the ohm reading is. Good luck! Larry Shepard |
04-17-2014, 04:43 PM | #16 |
My 75 MGB is a 12 volt car with a 6 volt coil. There is a resistor wire which is shorted out by an extra contact in the starter solenoid when you turn the key. This puts 12 volts to the coil to warm up the spark for starting. Many cars had similar setups hence the external resistors. Not many people know that.
Ian |
04-17-2014, 05:21 PM | #17 |
According to my parts man, all coils are 6 volts. The ones marked 12 volts are internally ballasted to reduce the voltage to 6 and the ones without the internal ballast will be marked to use an external ballast resistor. Use the coil and you may never change it.
04-17-2014, 07:33 PM | #18 | |
Hotrods don't have valve covers |
04-18-2014, 04:15 AM | #19 |
04-18-2014, 08:07 AM | #20 |
Until High Energy Ignition (HEI) came out in the late 1960s, 12-volt coils were usually 8-volt coils as were many of the 6-volt coils. If the 12-volt coil is pre-HEI, it should work with an input of 6 volts.
Early 12-volt ignition systems used an 8-volt coil. When the ignition switch was turned to the START position, 12 volts went to coil to provide a higher voltage spark. When the switch went into the RUN position, a resistor or resistance wire dropped the coil voltage to 8 volts.
Bob Bidonde Last edited by Bob Bidonde; 04-18-2014 at 08:14 AM. |
04-18-2014, 09:30 AM | #21 |
Ballast resistors were introduced at the onset of the use of 12 volt systems mostly in 1956. Ford used all three types at different times. The reason for ballast resistors in a 12 volt system is that the longevity of contact points is greatly shortened when used with 12 V. The resistor keeps the points from self destructing which they will in short order if run on 12V. 8V is border line 12V is unacceptable.
Chet |
