09-13-2013, 07:39 AM | #1 |
Downdraft Carb suggestions
I want to put a downdraft carburator on my stock model a engine. Which one should I look for? 81,97 or 94, and what is the best way to set it up?
thanks |
09-13-2013, 07:56 AM | #2 |
Re: Downdraft Carb suggestions
a weber ! best by far .......
V4f |
09-13-2013, 08:01 AM | #3 | |
Just out of curiosity, have you considered installing a Model-B carburetor & manifold for a little more airflow? With those, there is not a need for plumbing in a fuel pump when used on a Model-A. . |
09-13-2013, 08:37 AM | #4 |
Is there a quick way to ID the B manifold? Headed to a swap meet today.
09-13-2013, 08:48 AM | #5 | |
tk
anyone need some Model A restoration work done in Illinois? shoot me an email for pics and information [email protected] |
09-13-2013, 08:53 AM | #6 |
09-13-2013, 09:35 AM | #7 |
I have found the opposite of what Brent says. The 81 is adequate, and better than the stock carb, but the 97 is better, and cheaper. They usually need to be totally stock but sometimes may need a slight main jet change. I've tried them all.
09-13-2013, 10:12 AM | #8 |
I have a Weber on mine, and it works great. Can't compare it to any other DD, just haven't used them.
09-13-2013, 10:15 AM | #9 |
Stromberg 48,81,97 all run good on an A block. Of course you have to jet it correctly, but that's not hard to do. On a flat head you want the mixture to be a little rich, rather than lean. Lean will burn up a motor. People often refer to the 94 as a stromberg, but it's actually a Holley. It's he cheapest one out of all of them, but they tend to run leaner than a stromberg. I have a 48 and I love it, I had an 81 once and traded it for a weber and boy was that a mistake. The webers are fine, but the strombergs give you faster acceleration in my opinion and run better down the highway. The webers do get better gas mileage though. But not by much. I've tried most of the popular downdraft conversions, and the stromberg has been my favorite so far. You can usually pick up a 48 or a 97 in decent condition at a swap meet for about 75-100 dollars that needs rebuilding. For an 81 you can expect to give 250-300 for one that needs rebuilding, or closer to 400-500 for a rebuilt, if you can even find an 81. They reproduce the intake manifolds, and I think they're right around $200 for the manifold.
Cowtown A's |
09-13-2013, 10:16 AM | #10 |
I run dual updraft with B carbs. Its easy, bolt them on and thats it. I use original numbered jets. Gravity flow works fine, no pump or pressure regulator needed. This setup will run good, even on a completely stock engine. For best results with any mods on the model A, a higher compression head should first be added to really feel the improvement.
09-13-2013, 11:05 AM | #11 | |
09-13-2013, 11:30 AM | #12 | |
Ohh come on now Jim, when have you EVER had a stock engine?? |
09-13-2013, 11:31 AM | #13 | |
Charlie Stephens |
09-13-2013, 11:58 AM | #14 |
The B manifold is also "clocked" a few degrees toward the motor. How do you overcome this in an A and hook up the GAV?
09-13-2013, 12:26 PM | #15 |
Snyders has a kit to solve this problem. Look on page A-136. Part number A-9510-K Lists for $31.00 . Its kinda pricey for what it actually is. I cut the mounting flange off the manifold, rotated it as needed and brazed it back on. Be careful if you try this. The brazing job has to be good or you will end up with vacume leaks.
09-13-2013, 12:55 PM | #16 |
Here is a view of the setup on the speedster. The manifold is a cast iron uniflow that was made in the thirties. This manifold has larger runners and performs real good. I got this manifold from Berts, several years ago.
09-13-2013, 01:10 PM | #17 |
Here is a picture of the cast iron Trojan that I bought on eBay. This was taken when I was building the roadster. I've got better pics on photo bucket. Photo bucket seems to know which pictures that I want to post and most of the time won't let me. I had it working good late last night but not today. These pics are on Blue Melon. If I can get Photo bucket working again I'll post more.
09-13-2013, 01:28 PM | #18 |
Thats a really neat setup. Who cares if you cant make photobucket work, if you can make two B carbs work!
For Photobucket I always use the IMG link by the way, never had a problem |
09-13-2013, 03:16 PM | #19 |
A club member recently told the membership about his misfortune with a downdraft carburetor. His Model A is equipped with a downdraft manifold, downdraft carburetor, and an electric fuel pump. His thinking was that the fuel pump would block any fuel flow from the tank to the carburetor when the engine was shut off, therefore there was no need to shut off the tank valve. Wrong assumption.
He had not driven the car for about three weeks, when he went to do so he found that about four gallons of fuel had flowed into the intake manifold and into the engine, including the oil pan. His advice is to always shut the tank valve off. One would also hope that the tank valve has the ability to shut off 100%. Tom Endy |
09-13-2013, 04:31 PM | #20 | |
09-13-2013, 05:05 PM | #21 | |
Charlie Stephens |
09-13-2013, 06:48 PM | #22 |
I have a new English 97 on a heated Charley Yapp manifold. It runs noticeably smoother than the Zenith. Used an air/fuel meter to check jetting. smaller jets were too lean,stock jetting was just right.
It is a little touchy to start hot. I think I will try a heat insulator betweeen carb and manifold. Air filter in pic is too restrictive. A 4" tall K&N works good. |
09-13-2013, 07:21 PM | #23 |
I use an electric fuel shut off valve o a pair of 81's......keeps the "forget" part out.
09-13-2013, 08:16 PM | #24 | |
09-13-2013, 08:18 PM | #25 |
different angle
09-13-2013, 08:28 PM | #26 |
09-13-2013, 09:42 PM | #27 |
I also can vouch for the Weber set up. It was difficult to get the right throttle linkage travel range, either not fully opening or too fast at idle, but discovered some play in the two piece shaft & spring on my stock accelerator linkage but once corrected it runs very well and no longer has the constant gasoline in my attached garage. Only complaint is the chrome air cleaner supplied with it, looks tacky to me.
09-14-2013, 01:22 AM | #28 | |
Bill W.
09-14-2013, 09:45 AM | #29 |
I had a weber on my car, then I was convinced to put a stromberg on there. That was on it all summer. It was way more sensitive in pedal reaction and acceleration, but I didn't like it on the top end of cruising. It also seemed to run differently with every tank of gas. I switched back to the weber that never gave me a problem.
Cowtown A's |
09-14-2013, 10:01 AM | #30 |
Brent, When I bought my early '30 tudor several years ago it had a stock "B" engine in it, with "A" manifolds and carb. I ran this for a very short while but during that time the Auburn hill climb was being held twice a year. At one climb I ran it "stock", meaning as I bought it. For the next climb a few months later I had installed a Winfield 6:1 head, the times improved by a full second. That same day I installed an 81 on a Burns manifold, the times improved by another full second. For the next meet I had a 97 on the same manifold, and it picked up another 3/10 of a second. These were all averages of 2 or 3 runs. Shortly after that I came back to my normal self and put an early Miller under the hood. So for me, a stock B engine is as close to stock as I ever came, you caught me!
09-14-2013, 08:08 PM | #31 |
Feel free to send me all those crummy old Strombergs!
09-14-2013, 08:38 PM | #32 | |
09-14-2013, 10:16 PM | #33 |
Gravity flow can push fuel through a fuel pump & it must have had a funky needle/seat & slowly dribbled gas into the manifold & cylinders & leaked past the rings into the pan. Bill W.
09-15-2013, 03:26 AM | #34 | |
A phenolic spacer twixt carb and manifold fixed it As you say, stock jets have worked for me. |
09-15-2013, 12:07 PM | #35 | |
You cannot wire an electric fuel pump to the ignition circuit in a Model A with a stock ignition set up. If you do you will have the pump in series with the coil and parallel with the points and the engine won't run. The fuel pump did not pump fuel into the engine because it was shut off. The fuel fed by gravity from the tank past the stationary fuel pump into the down draft carburetor then leaked past the float valve in the carburetor and into the intake manifold. From there it was all down hill into the engine. An electrical shut off would not have anything to do with the situation. What was needed was for the owner to shut off the fuel valve under the tank and hope it had the ability to shut off 100%. This type of leakage does not happen on a Model A equipped with the updraft carburetor Henry delivered with the car. The updraft carburetor sits below the manifold and valve ports. Fuel leaking past the float valve in the carburetor ends up on the garage floor not inside the engine. Tom Endy |
09-15-2013, 09:29 PM | #36 |
Tom, thank you for your explanation. Even though my Model A engines are not stock, i do use the stock fuel tank shut off on the '29 CCPU.
09-16-2013, 09:36 AM | #37 |
The Weber works very well. We have it on the sedan and the roadster pickup. Tom's warning is correct for the shut off. Arizona Model A is a great source for the whole package to install the Weber. 480-782-0266 www.arizonamodela.com
09-16-2013, 11:19 PM | #38 |
Holley 92
I am replacing my Weber with a Holley 92 on a vintage Burns Intake. The Weber is a good setup, but I just cant get used to the "modern" look. In addition, i am replacing the stock head with a hi compression Cyclone head. The engine is stock rabbit. Hope it all works. I know I will have some plumbing design to do for the fuel line and electric pump. I have an indented firewall so mounting a pump on the inside of the firewall is not an option. Holly 92's are a little difficult to find, but I have run them in tandem on a hopped up banger and they are great. I assume a single 92 on a pretty stock motor will be ok. |
09-17-2013, 12:10 PM | #39 |
