05-16-2013, 08:03 PM | #21 |
Re: Painting Wheels - Spin Speed
Brent -
Do you prime the wheels say using DP 90 before final paint? I do not want to use a sand able primer (such as PPG K36) because I don't want to lose details. I think I remember you saying that you just shoot the color over a properly sanded wheel. Am I correct? Thanks - Hunter |
05-16-2013, 08:11 PM | #22 |
Sorry Brent - One more question
When you say slow solvent do you mean a reducer with a higher temperature rating than the ambient temperature. For example if it is 70 F and you use DT 85 instead of DT 70 is the DT 85 considered a slow solvent? Sorry for my confusion on this - Hunter |
05-16-2013, 10:49 PM | #23 |
I built a rotisserie to paint my wheels on. Each wheel is mounted between cones like a wheel balance would have done and the wheel will hang out in mid-air on the horizontal arbor so that I can paint it from four different directions. You can paint every corner this way. The wheel arbor is belt driven off of a variable speed drill. The wheel speed that works best for me is about 1 rpm and just a little slower. The wheels' paint always come out looking like glass and with no paint runs. After painting each wheel, I let it spin dry at 1 rpm for about an hour, and then I go on to painting the next wheel. I found that a BBQ rotisserie is not strong enough and it will strip out its gears. A tip here is to straighten your wheels before you paint them. I painted 8 good looking wheels. In the end, I only had 4 straight wheels without wobbles.
05-17-2013, 06:50 AM | #24 | ||
How I think this applies to Model-As is generally speaking, restorers like to apply too much mil thickness of paint, --either with the topcoat or with substrates which these extra materials cause the paint finish not to be as durable. Therefore I feel my way greatly reduces the chance for chips and trauma which ultimately protects the wheel from having rust form under the paint. The second part of this mindset is the environments by which most of our vehicles see. Most tend to reside in a garage and are treated with care, however lets look at it a different way and suppose the vehicle was left outdoors and treated with much more disrespect. I suppose it is plausible in those environments where the paint applied in my method could only last for 10+/- years or so before rust particles under the paint would start to release to paint in areas. My take is this is not that big of a deal in that the labor & material savings by limiting the substrates and the labor involved in working those substrates now would offset the price of possibly needing to recondition the wheels in 10 years (when the old tires need to be replaced anyway). I also think it is plausible that if you have "thick paint" on a wheel and left them in the same environment, then you will likely be repainting them in 10 years too. Therefore I feel it boils down to goals and whether you are wiling to take a chance on longevity but again, 95% of the cars will never see the harsh environments that would cause premature failure. If they did, the paint on the wheels probably wouldn't be the only thing needing reconditioning! Quote:
05-17-2013, 07:18 AM | #25 |
There was an old saying in the paint biz that enamel was it's best "primer" over properly etched steel. The key word there is "etched". Sand blast, chemical treatment, combination of the 2, if the wheels are clean and have a good tooth then Brent's method is by far the longest lasting result. Those who scream the loudest against can't seem to answer why something like Rustoleum lasts so long outdoors with no treatment or care what so ever. Even silver fence paint lasts over a decade unless it borders a lake or the ocean. My old neighbor would do his every 12-15yrs.
Also Brent, dead-on-balls about slower dry times. The longer that "wet" paint has to permeate the etch on the metal the better. Our catalyzed materials in use today are far more flexible than powder or even the old enamels of the past, and the thinner it is (mil thickness) the more flexible it remains. Just peel a layer off the inside of plastic cup and you'll see it has nearly the same characteristics as Saran Wrap. I have Packard wire wheels painted over bare metal from 20yrs ago, but also as stated they never get left outdoors for very long (!!!). |
05-17-2013, 07:28 AM | #26 |
Pete's Ponies Mustang RUSToration & Performance |
05-17-2013, 10:03 AM | #27 |
Anybody think of this? Spin the wheel about 15 rpm and allow centrifugal force carry the paint out on the spokes. I hate to paint any rotational parts and leave them standing in one position for long. I haven't tried this yet, but I'm building a "Wheel Lathe" out of an old headstock from a lathe. This creation of mine will handle any size wheel down to lawn tractor which is another issue. Just wondering!
Terrry |
05-20-2013, 01:29 PM | #28 |
Ken, Gary, Brent, and all -
Thanks so much for all of your advice, wisdom, and experience. Attached is a pic of a device i put together to spin the wheels. I could vary the speed of the wheels using this device. When I started using this I found that I was always cuting it off and moving the wheel orward and backward manually so that I could target the spray. I should have just hung tehm on a piece of the pipe and saved myself the trouble. The only time I felt the device was helpful was after shooting each whee completely I could let it spin dry. My advice to anyone else -No need to get fancy. Go with the experts and hang them on pipe and spin them manually. Live and learn - Hunter |
05-20-2013, 02:45 PM | #29 |
Hunter, I think you hit specifically onto something that is a disease for many restorers. Often times we feel we must have a fancy specialty tool to accomplish each task of the restoration, ...and therefore we waste 3X as much time making such a tool just so we can save a few minutes in that restoration task. It is no wonder many restoration projects take many years to complete because of the times we get side-tracked making labor-saving tools instead of doing it with what tools & resources we already have!!
05-20-2013, 06:23 PM | #30 |
How did the dealers paint the wheels back in the 29-31 time frame. Spray, brush, dip?? I'm sure there wasn't consistency dealer to dealer??
Paul in CT |
05-20-2013, 06:45 PM | #31 | |
Paul, based on what I have researched most dealers just stocked colored wheels that the branch had dipped. DeVilbiss invented the spray gun in 1925 and I have a 1927 sales literature where it showed how dealership could open a paint shop to increase profits. The cost was pretty expensive for the day and I would venture a guess that only the most wealthiest of dealers could afford it. I would say that towards the end of 1930 is when even the majority of all Ford agencies had a bodyshop. Up to that time, you ordered the replacement sheetmetal painted and ready to install. The same with wheels I would say. |
05-20-2013, 08:15 PM | #32 |
Thanks Brent ! !
Paul |
05-20-2013, 08:51 PM | #33 |
I have a question on spinning wheels on a pipe. How do you spin a wheel once it is almost painted without messing up the paint just applied and getting paint on your fingers? Do you just try to spin it by trying to pushing it on the inside part or use a very thin piece of metal and push a spoke? I can see at first there is no problem, but as it is getting close to done and you are trying to get to some places where you might have missed, it seems difficult to do without maybe messing up the paint you just applied. I plan to paint some wheels for my phaeton and am interested in an easy, but good way to do it. BTW, our club has a wheel spinner in our tool loan program. The problem I see with that is you can only do one wheel at a time. I see no way to remove the wheel just painted to mount another wheel for painting.
Rusty Nelson |
05-20-2013, 09:11 PM | #34 |
Rusty,
I just finished painting two wheels. I used professional Rustoleum (sp?) and this paint will dry in a very short period of time. Thus you can remove the wheel from whatever setup you have within a hour or so. Yes it is slow doing on wheel at a time. I used a screw driver in the valve hole to spin the wheel when I had to much paint on it to do it by hand. Here was my setup. I can send you more pictures if you like. Just PM me.
Fred Kroon 1929 Std Coupe 1929 Huckster |
05-20-2013, 09:50 PM | #35 |
You can check out a wheel spinner we built at Honest Charley Garage that I used to paint some wood spoke wheels for a 1913 American Underslung.I found it turned the wheels a little fast for my liking, so i ended up turning them by hand.
Check us out on U tube and search 1913 American Underslung wheels |
05-20-2013, 10:28 PM | #36 |
Fred,
Thanks for the information. It appears that using a pipe might be the best method. Using the tire valve hole to turn the rim is a good idea. It will be a whie until I paint the rims so I can decide later. This string is full of useful information. Rusty Nelson |
05-21-2013, 06:01 AM | #37 |
Rusty, again do not make it complicated. Use your finger (with gloves on) and touch the wheel where the rubber band will later reside inside the rim. If your finger prints that area, it really does not matter and if the paint is messed up under your finger, give it a shot with the spray gun. Too much time is wasted with a screwdriver trying to find something to push against, plus you run a risk of damaging something over using your finger which you will have better, & faster control with.
05-21-2013, 06:40 AM | #38 |
I paint wheels on a 20 foot length of one inch round bar stock.I usually prime them outside,hanging the bar between a couple of old trucks or bulldozers.I paint the inside of the hubs beforehand,and they never seem to take any damage spinning them on the bar.I just turn them with my finger,yes,I get paint on it,you can't make a cake without breaking some eggs.I could never see the point of a spinner,mixing paint and primer 10 times and cleaning the gun 10 times for 5 wheels does not look like fun to me.I still have quite a few gallons of DP 40 primer I'm using on wheels and such.That has to sit after mixing for 1/2 hour before spraying.A spinner is a lot of work and waiting for a simple operation.
05-21-2013, 07:09 AM | #39 |
I use an extension ladder laid horizontally. Set the wheels in between the rungs.
05-21-2013, 07:12 AM | #40 |
I would think that a dowel through the lug holes would work fine for a place to spin. You won't want paint built up there anyways.
