11-26-2022, 12:25 PM | #1 |
Phaeton door panel nail & socket
Anyone know of a source for the nails and sockets to install the door panels on a 1928 -29 phaeton?
11-26-2022, 06:19 PM | #2 |
Re: Phaeton door panel nail & socket
I have a bag of these, about 25 or so you can have for the cost of postage.
PM me your information. |
11-26-2022, 07:05 PM | #3 |
If you don’t make a deal I’d be happy to have them..
DJ |
11-27-2022, 09:54 AM | #4 |
They are gone.
11-27-2022, 05:07 PM | #5 |
Thanks
12-04-2022, 07:37 PM | #6 |
12-04-2022, 07:44 PM | #7 |
Gpierce
Can you let us know where you got them. Thanks. |
12-04-2022, 08:15 PM | #8 |
They came with my CCPU project which came in many bits and pieces.
I opted not to use them in my doors due to the difficulty of removing the door panel should I need to. That was a good decision as I had a window lift fail. Once they are installed I don’t know who you remove them as the nails have very pronounced barbs on them. I suspect you might have to cut heads off. I used Honda Nylon Nuts A14255 which fit as flush as the Ford brass parts. They fit nicely in the original holes in the door. It’s been six years but I vaguely remember having to trim a corner or burr very slightly on the nylon insert (nut). In place of the serrated nails I used slotted head #6-32 machine screws. They tightened up nicely and we’re easily removed when I had to remove the door panel. Obviously not a fine point installation but a serviable one which was my intent. https://www.clipsandfasteners.com/se...A14255&Submit= Last edited by GPierce; 12-04-2022 at 08:53 PM. |
12-06-2022, 10:13 PM | #9 |
Looks awesome and will definitely keep this in mind for other builds, but still without any luck, I'm Searching for the original brass ones. Thanks though I appreciate the reply, most can't be bothered I guess
