Old 03-17-2012, 02:24 PM   #1
hardtimes
hardtimes's Avatar
Default Crankshaft Q...
I checked out cost of a new B crankshaft and it's nearly $1800(drilled). What would you consider paying , as a fair price, for a nos counterweighted B crank...if you located one?
hardtimes is offline   Reply With Quote
Old 03-17-2012, 03:40 PM   #2
ursus
Default Re: Crankshaft Q...
I bought a counterweighted B crank that had been turned down to 10 thousand under and guaranteed crack free for $400 a couple years ago. You could also use an earlier uncounterweighted B crank and have the weights attached to it. Some prefer this option and say that the earlier crank is actually stronger because of more metal at the cheeks of the crank throws.
ursus is offline   Reply With Quote
