03-16-2012, 07:47 PM | #1 |
how to tighten upper plate
Is there a way to tighten the fit of the upper plate in the distributor housing?
if I push mine side to side it changes the point gap. I don't know if this makes a difference,but I would like a better fit. It seems that I read something about this. John |
03-16-2012, 07:57 PM | #2 |
Re: how to tighten upper plate
The spring should hold the plate up. There are 3 ears on the plate that ride in the housing, put each one into a vice and bent part of each ear down slightly. This will tighten up the plate.
03-16-2012, 07:59 PM | #3 |
The plate centers on the housing casting which wears after time. I have thought about donig some lathe work to make a bushing to replace the worn casting. Never went by the thought stage since I have a large collection of original housings.
Gar Williams |
03-16-2012, 08:24 PM | #4 |
See post #7 to see how to tighten the fit of the plate.
LINK https://www.fordbarn.com/forum/showthread.php?t=62458 Bob |
03-17-2012, 07:27 AM | #5 |
