03-15-2012, 05:53 PM | #1 |
Alternator help please
This question is about an alternator I aquired with an engine awhile back. I do not have any history on it and would like some help from someone that knows much more about these things than I do.
Questions are: 1. Is it a 6 volt alternator? 2. In looking at the end of the alternator opposite the pulley (see picture), I know the one connection that is at about 10 o'clock says Bat. But what is the one that is down at about 8 o'clock for? 3. On the "top" of the unit (see picture) it has two plug type things and it shows a "12" right below these plugs. What is this for? Rather than ask so many questions here, is there somewhere I can go and look up how to install an alternator like this? Thanks again for the help.
Fred Kroon 1929 Std Coupe 1929 Huckster |
03-15-2012, 06:26 PM | #2 |
Re: Alternator help please
its a chevy 12v three wire internally regulated alt, the lug way down on the alt all by itself is a ground connection, the two spades on top of alt are for power, run a wire from #2 spade to the batt termal on alt, #1 spade goes to the ign switch hot wire and it is only hot when key is on, it is there to excite the built in regulator, basically it turns the alt off when key is off, you can also hook it to the idiot lite wire to put the light out when alt is charging, its only hot with key on, its a chevy 3 wire alt and the only one to use, the one wire causes to much trouble, some times it will stay excited when engine is stoped and discharge the batt over night, i use the 3 wire type becaus they are so easy to wire and install, its easy to make a mounting bracket for them, only need one mounting bolt and one adjusting arm and bolt to tighten it
03-15-2012, 06:41 PM | #3 |
Sounds like it is something I don't need for my stock A's. Like I mentioned I picked it up with an engine I acquired awhile back. Looks like I need to put it on the swap site and see who may want it.
Thanks for the information.
03-15-2012, 06:48 PM | #4 |
Les Andrews Model A Ford Mechanics Handbook Vol. 2 has this info!
www.whidbeymodelaclub.com |
03-15-2012, 09:58 PM | #5 |
the way it has the bar from the + terminal to ground, and a modified - terminal I think it is a converted to 6V +ground modified chevy alternator and what goes into the regulator terminals 1&2 on the edge depends on how it was modified.
03-16-2012, 12:04 AM | #6 | |
http://mightymo.org/Proj_OneWire.html http://www.alternatorparts.com/10si-all-in-one.html - Scroll down for parts convert/repair your alt. PS - This information comes to you from a "purist".
What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do some thing about them. - Henry Ford II Last edited by Mike V. Florida; 03-16-2012 at 12:17 AM. |
03-16-2012, 11:17 AM | #7 |
Please note that the #1 terminal of these type altenators connect to the igniotion switch hot wire on later cars. The ignition switch on a Model A if original wiring is used is between the coil and the points. If you make this connection with this altenator it will not work! If you plan on using terminals 1 and 2 on the altenator, you will have to put a diode between the #1 terminal and the hot side of the coil. You will also have to put a fuse on the vehicle as the connection on terminal #1 is for the field coils in the altenator and will draw current when the car is shut off. You must pull this fuse when you shut it off or your battery will run down. Have an instruction sheet about this modification if you would like more info. Send me an email [email protected]
03-16-2012, 01:27 PM | #8 |
Thank you all for the help. Especially Mike and Jrelliott. Being you can tell I know nothing about alternators, I think I will pass on trying to use this thing. But your help gave me some idea what I would have to do in using it. I think I will pass it on to someone that has more use of it than I do. I still have a good working generator that I think I will use in putting this engine in my coupe. If anyone has a use for it, let me know.
