Old 03-12-2012, 06:53 PM   #1
texas webb
Default WireWheel Fit Question
I may have a dilema.I bought a pair of wheels from a hamb ad here in Texas and they measure 5 1/2 center to center not edge to center so they are 5 on 5&3/4 best I can judge.Supposedly 34-35 packard rims,Can any thing be done via a welded ring on the back to drill the proper lug spacing?These rims are bent spoke and look just like 35 wires but thicker steel and 5&1/2 wide.Thanx for any help.I was planning to use these on the rear for my AV8 project.
texas webb is offline   Reply With Quote
Old 03-12-2012, 08:15 PM   #2
B-O-B
B-O-B's Avatar
Default Re: WireWheel Fit Question
Think you are measuring wrong. Never heard of measuring edge of hole to center of hole. If they measure 5 1/2" they should fit unless the backside of the rim won't go over your brake drum. I usually measure left side of the left hole to left side of right hole or center to center.
B-O-B is offline   Reply With Quote
Old 03-12-2012, 08:36 PM   #3
texas webb
Thanx,B-O-B.I"ve always thought it was left side of stud to c/l 3rd stud.They seem to be 5 on 6" and dont fit ford hubs.
Old 03-12-2012, 09:00 PM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
When all else fails to answer your question, just see if they will fit a drum with a 5 on 5-1/2" bolt pattern.
John
Old 03-12-2012, 09:17 PM   #5
Randy in ca
Randy in ca's Avatar
You were measuring correctly to get an approximation of the bolt circle diameter. A center to center measurement will only work if you have an even number of studs, not with 5 studs.
Randy in ca is offline   Reply With Quote
Old 03-12-2012, 09:22 PM   #6
texas webb
JM 35 I checked with my drums,no go.Randy, thats how I measured thanx.
Old 03-13-2012, 06:21 AM   #7
jimTN
If they are Packard, you should be able to sell them very easy and buy several sets of bent spoke KH wheels.
jimTN is offline   Reply With Quote
Old 03-13-2012, 07:13 AM   #8
texas webb
Yeah,Jim.Found out they are 30"s Buick.I"m searching for adapters,the"re nice wheels.Thanx to all,Webb.
Old 03-13-2012, 03:02 PM   #9
Bassman/NZ
Bassman/NZ's Avatar
I doubt adapters are going to be available. If you are set on using them, the solution is to drill a new stud pattern in your hubs/drums.
Bassman/NZ is offline   Reply With Quote
