07-27-2011, 10:00 AM | #1 |
Oil Pump question
I have oil pump out. In a pan of gas I can't turn it fast enough to get it to pump. Put a drill on it and it squirts out good, I guess about 6" or so. I had read in a previous post that if you restrict it it will pump lots of pressure. I put fingers over holes and had no problem holding, so not much pressure. However some gas came up around the shaft so it wasn't restricted completely. Is there a good way to tell the efficiency of the pump?
07-27-2011, 10:44 AM | #2 |
Re: Oil Pump question
Gas is most likely WAY too thin to allow the pump to work right. You need to try it with oil, I think you will be surprised in the difference.
07-27-2011, 01:50 PM | #3 |
I think these pumps are pretty bulletproof.. What are the clearances and how worn are the end plates?? If the end plate is worn is can usually just flip it.. I'd re-try it with oil also, it'll probably start working..
07-27-2011, 02:10 PM | #4 |
Oil is much safer than gas also. Turning a pump with an electric drill in gas is an invitatioin to disaster......
07-27-2011, 11:18 PM | #5 |
yes the gas does not lubericate and can dislodge crap in the pump. take it apart and inspect it. do it now or later.....Dave
07-28-2011, 12:58 AM | #6 |
07-28-2011, 08:02 AM | #7 |
You might not need the gasket on the bottom if the gears are short enough. You do not need a leak-tight seal at the bottom. The clearance between gears and bottom should be as small as possible in order to maximize pump efficiency.
