Old 07-27-2011, 09:06 AM   #1
mrtexas
mrtexas's Avatar
Default More early AR parts
Up until today I didn't realize the E28 had a shorted choke rod and a lower location for the bracket on the gas tank. E28 on top is from my early 28 open cab pickup.
mrtexas is offline   Reply With Quote
Old 07-27-2011, 09:22 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Another early AR part
My 9-27-28 also has the teardrop choke rod and the mounting bracket under the gas tank forward of later choke rods.
Old 07-27-2011, 03:23 PM   #3
mrtexas
mrtexas's Avatar
Can someone concur with another observation?
None of the instrument panels that fit my 29 roadster will fit my E28 gas tank. E28 is a special instrument panel?
Old 07-27-2011, 04:02 PM   #4
Maclab58
Maclab58's Avatar
Default Re: More early AR parts
My AR has the same short GAV rod. Also have the bracket that is forward of the later models.
Maclab58 is offline   Reply With Quote
Old 07-27-2011, 04:45 PM   #5
Steve Ciccalone
Steve Ciccalone's Avatar
The early panel is different only that it does not have a clipped or flat top at the 12 o'clock position.
"A wet bird doesn't fly at night."
Steve Ciccalone is offline   Reply With Quote
Old 07-27-2011, 04:50 PM   #6
Fred
May I add, Or counter sunk holes on the bottom two screw holes..
Fred is offline   Reply With Quote
Old 07-27-2011, 06:07 PM   #7
mrtexas
mrtexas's Avatar
I measured the width of both the E28 and 29 and there is a difference in where the bottom 2 screws attach by about and 1/8 of an inch.
Old 07-27-2011, 06:11 PM   #8
mrtexas
mrtexas's Avatar
It would be nice if someone else with an E28 would measure the distance between the two bottoms screws! My 29 screws are3 1/4 inches center to center.
Here is from an earlier post that I did not get an answer from someone`!
"I got my micrometer out and measured the distance between the screw holes and low and behold, on the E28 the bottom holes are about 1/8 inch farther apart, just enough difference I can't put the bottom screws in."
Old 07-27-2011, 06:33 PM   #9
d.j. moordigian
d.j. moordigian's Avatar
mrtexas,
Steve & Fred are both correct. My early tank, no tank number but has the forged
chock rod mount, measures very close to 3.25" using calipers.
d.j. moordigian is offline   Reply With Quote
Old 07-27-2011, 06:48 PM   #10
Tom Wesenberg
Are you working with a REPRO instrument panel? The bottom 2 screw holes on them are off by about 1/8", which is just enough so you can't install the screws.
Old 07-27-2011, 07:31 PM   #11
glenn in camino
glenn in camino's Avatar
My 6/1/28 tudor has the short choke rod.
glenn in camino is offline   Reply With Quote
Old 07-27-2011, 09:01 PM   #12
mrtexas
mrtexas's Avatar
Can't say. I have 4 or 5 panels and ALL fit my 29 perfectly, none fit my E28.
I'll check tomorrow to see if the lugs have been deformed.
Old 07-27-2011, 10:33 PM   #13
dean from bozeman
dean from bozeman's Avatar
Short choke rods are for the first two generations of gas tanks. The first generation is referred to as the "strap" gas tank. Its choke rod support is made of steel that is rolled flat and is approximately 1/2 way under the tank. The second generation is found in the same position but made of forged steel. The third generation is also made of forged steel and is moved closer to the passenger. Using front/back or forward/distal just don't work as well when describing the location.
dean from bozeman is offline   Reply With Quote
