07-26-2011, 08:14 AM | #1 |
Runs Great Than act like it starves for fuel
New here, been learking for years but now I have a problem I can't figure out.She runs great for about 5 miles than starts sputtering like it's starved for gas.If I pull out on gav some she still will run like a top.new coil ,new plugs ,new condenser.Today I'm going to drain the gas and check gas filters,cars been sitting awhile so maybe filters are plug with crap,than check carb,I hope to get her done for Model a days in Amana Iowa on the 20th.Thanks for your help you guys are GREAT....John
07-26-2011, 08:18 AM | #2 |
Re: Runs Great Than act like it starves for fuel
I would say you are on the right track. Sounds like plugged fuel filter to me. When it starts to run poorly, also try reaching out and removing the gas cap, see if that helps. The vent holes could be plugged up (insect nest while car sat, etc.).
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" |
07-26-2011, 08:21 AM | #3 |
loosen the gas cap and see if it runs better
07-26-2011, 08:25 AM | #4 |
It sounds like a fuel delivery issue.. Try driving it with the gas cap loose and see what happens, or, remove it and check for the vents.. Sometimes the gas and radiator cap can get mixed up.. You could remove the fuel line at the carburetor and check for fuel flow and that the fuel line doesn't extend too far into the carburetor.. I think these are the easy things to look at first..
07-26-2011, 10:08 AM | #5 |
Sounds like it could also be a bad condenser?
07-26-2011, 01:01 PM | #6 |
Like "gas logged" pieces of cork from the gas gauge float or filler cap or pieces of solder from some one fixing leaks in tank. I am talking about a thin flat piece of solder like you get when you "flick" a gob of hot solder off of a hot iron ... I call them "solder splats". Looks like a spit ball on the wall! A "finger filter" that goes inside the shut off valve inlet will prevent these problems. Last edited by Benson; 07-26-2011 at 03:33 PM. |
07-26-2011, 01:15 PM | #7 |
Trash somewhere in your fuel line, or the hole in the gas cap that allows air into the gas tank is clogged.
I had this happen on a car. There was a tiny piece of crud lodged in the needle and seat of the carburetor. Easy fix and back on the road in no time.
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
