07-25-2011, 10:26 PM | #1 |
Snyder's 2 Blade Aluminum Fan Looks Good!
A customer bought 2 aluminum fans from Snyder's and had them mailed to me for balancing. I was really impressed at how much better these two fans looked over the ones I'd balanced a few years ago. The blades are much straighter, and parallel with each other, and the balance was so good that I won't do anything to them. The taper to the shaft is a perfect fit also. The finish was also smoother than the fans of a few years ago. To check the balance I place the fan on the shaft and let the blade settle out to find the heavy side. I then remove the nut and place the steel strap in a vertical position behind the nut. I then slide the magnet out until the fan stops at random positions when I give it a light spin. This fan was in perfect balance when the 9.6 gram magnet was placed 3/4" from the center of the shaft. This translates to having a balance of 1 gram at 7" radius, which is very good. In the past I'd drill holes on the lightest side of the hub (on the front side), then fill them with lead (melted wheel weights) until the fan had the right balance. |
07-25-2011, 10:57 PM | #2 |
Re: Snyder's 2 Blade Aluminum Fan Looks Good!
Tom,
I followed ALL of your past input relative to aluminum fans and the problems that you found. I also noticed that there were those that reported 'broken' aluminum fans(just like broken other type model a fans). Your prior findings is why I never bought an aluminum fan for my As. Two out of two , in near perfect balance, is not bad! Are you saying that , in your opinion, buying an aluminum fan (Snyders)would be a safe purchase now? Are all aluminum fans made/distributed from ONE source..if you know? |
07-25-2011, 11:24 PM | #3 | |
07-26-2011, 02:27 AM | #4 |
Not long ago, there was an extensive "fan' discussion. If I remember correctly, remarks/input there will reveal that broken aluminum fan(s) was reported. Tom's current remarks/work made me wonder if that persons aluminum fan was of the original try at making aluminum fans. Mabe that person(s)will note this thread and comment again.
07-26-2011, 04:02 AM | #5 |
I remember only one person that said he lost a blade, and that would have been some years ago. Judging by these two fans I'd say it would be a good fan to buy now. I hope these two fans are typical of all the fans now being made.
07-26-2011, 06:29 AM | #6 |
07-26-2011, 08:37 AM | #7 | |
07-26-2011, 09:06 AM | #8 |
07-26-2011, 09:50 AM | #9 |
I bought one for my 28' about 6 months ago. I read a lot before hand and made me worry about the balance and fit. The original was starting to look suspect and with a ton of people recommending them I bought it.
It fit well (I am also using a leakless water pump) and runs smooth. I'm very pleased with it. |
07-26-2011, 02:51 PM | #10 | |
Reviewing Mitch's comments ..what do you thing about: 'instructions' on grinding (yikes!) |
07-26-2011, 03:20 PM | #11 |
One manufacturer as Brent said. Then distributed to different vendors.
07-26-2011, 03:37 PM | #12 |
I'm very pleased with my aluminum, two bladed fan from Snyders.
Rog |
07-26-2011, 09:43 PM | #13 | |
Cowtown A's |
07-26-2011, 10:26 PM | #14 |
07-26-2011, 10:37 PM | #15 |
It was a couple years ago. But weve also had failures from everytype of fan made. Both types of originals have failed and thrown the fan blades in the engine compartment, we had a 6 blade fan saw off the waterpump shaft and go threw the radiator, and the 2 blade aluminum hub split.
Cowtown A's |
07-27-2011, 12:38 AM | #16 |
Some earlyier aluminum fans had the taper not wuite right from what I've heard. They shoule be good now, and it's also a good idea to place a thin STEEL washer behind the nut.
Snyder's makes, or has the aluminum fans made for them and then distributes them to other dealers. |
