07-24-2011, 12:27 PM | #1 |
Rebuilding/Flow Testing Jets in Zenith Carbs
I am rebuilding my Zenith 1 and Zenith 2 carbs. I drilled out all the plugs and cleaned the passageways with long shank drill bits turned with a hand-held brace-and-bit-device. My flow tester is a self contained 4 gallon unit with a head of 37 1-4 inches. In prior testing, I used 4 gallons of distilled water. Do you recommend using a different liquid medium such as plain tap water, a percentage of alcohol such as 3 gallons water and 1 gallon alcohol, etc or some other liquid mixture? Do you recommend changing the flow rates of the jets (in the past I used Steve Pargeter's flow rates) to compensate for the alcohol in fuels today? I value and appreciate all information, advice and your recommendations.
Bill Lee/Virginia Peninsula |
07-24-2011, 01:43 PM | #2 |
Re: Rebuilding/Flow Testing Jets in Zenith Carbs
Tap water has worked just fine for me when flow testing jets. I guess gasoline would technically be the best fluid to use, but I think that tap water is close enough for this sort of testing.
I am lucky enough to still have a non-ethanol gasoline station within a mile of my house. I would think that if you were always going to run ethanol fuel, perhaps about a 7% increase in flow rate would be about right to offset the lower energy content of the ethanol fuel. |
07-26-2011, 02:20 PM | #3 |
Soldered jets closed then re-drilled them to specs, never flow tested them. Very big difference in performance all the way around.
Used the Dallas Model A Ford Club's specs from the Carbs and Carbohydretes video. The repo jets were so far off, amazing how the car even ran. |
07-26-2011, 03:38 PM | #4 |
You should flow test the jets with the liquid used in determining the flow rates you are using for comparison. All the rates I have seen are for water.
07-26-2011, 04:50 PM | #5 |
07-26-2011, 05:00 PM | #6 |
