Old 07-20-2021, 09:41 PM   #1
Bob from Northport
Bob from Northport's Avatar
Default Brake light switch
We have a car in my shop that was purchased by a customer from Mecum auction. There is nothing on this car that isn't broken or worn out completely.
We found this on the brake light switch when I was removing the brake cross shaft. One of many things we have seen.
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 07-20-2021, 09:54 PM   #2
Ernie Vitucci
Default Re: Brake light switch
Good Grief! Ernie in Arizona
Ernie Vitucci is offline   Reply With Quote
Old 07-20-2021, 10:27 PM   #3
NZ28ModelA
NZ28ModelA's Avatar
Talking Re: Brake light switch
But does it work!!!
NZ28ModelA is offline   Reply With Quote
Old 07-20-2021, 11:29 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Add that one to the farmer fix list.
Old 07-20-2021, 11:32 PM   #5
Ruth
You get a car and free tools too? What are you complaining about?
Ruth
Old 07-21-2021, 02:00 AM   #6
Patrick L.
Patrick L.'s Avatar
Ahahahahaha ! Wouldn't it have been easier just to fix the darn thing right ! They must have just forgot, last thing they did that day, ran out of time.
Old 07-21-2021, 06:09 AM   #7
jb-ob
Only thig worst than used car sales are amateur used car sales.
jb-ob is offline   Reply With Quote
Old 07-21-2021, 09:31 AM   #8
frank55a
If there are no holes in the cross member for the switch to bolt to, I would guess the A is a 29 as it does not appear to have the 3 piece brake system. If so, the switch is incorrect and it should have a switch mounted on the transmission.
Apparently, the person that mounted that switch had no idea what was correct OR he could not remove the floor boards, OR it was a roadside emergency fix.
frank55a is offline   Reply With Quote
Old 07-21-2021, 12:54 PM   #9
1931 flamingo
1931 flamingo's Avatar
Buyer obviously did NOT inspect car ("There is nothing on this car that isn't broken or worn out completely.") or had too many drinks. Wonder what he ended up paying??
Paul in CT
Old 07-21-2021, 02:29 PM   #10
Bob from Northport
I'm afraid to ask how much the owner paid. It is a 30' Roadster to answer another question above. The switch is correct, but the brake rod to the switch is bent badly.
The main reason for the post was to show how important to have someone on hand that knows these cars, not just through dreaming eyes.
Bob from Northport
Northport, Michigan
Old 07-22-2021, 11:25 PM   #11
Tom Wesenberg
Yep, on most large purchases I like to look it over, then go home and think it over, then go back for a second look. The second look often see things missed the first time.
If the thing is a good buy though, you may have to act quickly or loose the deal.
Old 07-23-2021, 08:43 AM   #12
rotorwrench
rotorwrench's Avatar
Folks will purchase a car that looks good even if it doesn't work good. Roadsters are popular cars and the prices reflect that. Auctions don't always let prospective bidders know the condition of a vehicle so a person has to look it over as much as the owner & auction company will allow and know what to look for. Not all people that purchase at auctions are car guys so this stuff is bound to happen.
Old 07-23-2021, 12:57 PM   #13
gdmn852
gdmn852's Avatar
Hello,even when looking several times there are things you may miss , on my car they had access to a welder but no hardware stores every thing tack welded. I have wondered about those auction cars, “ buyers remorse “ when they get the car home
gdmn852 is offline   Reply With Quote
Old 07-23-2021, 03:01 PM   #14
Patrick L.
Patrick L.'s Avatar
Hmmm. Buyer beware, even at Mecum. From what I've watched of their actions, nothing is cheap.
Old 07-24-2021, 12:10 PM   #15
burner31
burner31's Avatar
I see this as a positive...got a free C-clamp
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 07-24-2021, 12:42 PM   #16
Patrick L.
Patrick L.'s Avatar
Yep, one can never have enough c-clamps !
Old 07-24-2021, 04:50 PM   #17
160B
160B's Avatar
On top of it all the switch is the cheap reproduction that does not have the brass bushings for the shaft to ride on!!! JUNK!!!
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
