Old 01-18-2020, 01:47 PM   #1
farmerdick
farmerdick's Avatar
Default 32` Hood on a 30`Model A
Will a 32`hood fit a 30` Model A with 32`grill?
Thanks
farmerdick is offline   Reply With Quote
Old 01-18-2020, 02:42 PM   #2
Charlie Stephens
Default Re: 32` Hood on a 30`Model A
Thanks
NO, the belts on a '32 won't match the Model A and the bottom of the 32 side panel curves down, see first 3 pictures. The last two show the same areas on a Model A. When using a '32 shell on a '30-'31 Model A you need to use the Model A hood. You will need a mount for the front of the Model A hinge. Note also that the '32 shell will not go directly onto a Model A radiator, the fill neck is too for forward on the '32 shell and the fill neck will need to be moved. An alternative is to shave the '32 shell and mount the fill cap under the hood. Another alternative (that I am using on my '32) is to remove the radiator neck and install a '32 cap and bezel with a fabricated bracket to hold the cap on to the shell. With the radiator fill under the hood you can use a pressure cap.
Charlie Stephens
Old 01-18-2020, 02:45 PM   #3
deuce_roadster
deuce_roadster's Avatar
This is such a common thing I would contact Rootleib and see if they make a special hood that fits the model A cowl and the 32 shell.
Old 01-19-2020, 12:40 PM   #4
rotorwrench
rotorwrench's Avatar
A lot folks have fabricated their own set ups over the years or they run hoodless. There are aftermarket tops that can be used to fabricate a hood. The 30-31 hoods for 32 shell are a lot more common and are available from several sources. The 28-29 are the more difficult ones to fabricate since the shell has to be shortened to work properly and the cowl is different.
Old 01-19-2020, 06:09 PM   #5
Chris Haynes
Chris Haynes's Avatar
My 1930 roadster hood fit with the '32 shell. '28/'29 may differ.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 01-20-2020, 11:16 AM   #6
Bob/Ohio
Bob/Ohio's Avatar
I have a 30 A with a 32 grille shell, and I am using the stock hood. I made the front hood bracket to fit the 32 shell. I just recently converted my A hood hinge to a 32 style hinge also, and used 32 style brackets on both ends.
Bob
Bob/Ohio is offline   Reply With Quote
