06-30-2013, 05:34 PM | #1 |
Help! Brakes pull to left
Need help fast- I rebuilt the brake cylinder on the right rear of my roadster and now it literally dives to the left when braking hard. The brakes are Locheed post war 42-48 brakes with only the top adjustment cams. Long shoe is towards the front and short shoe towards the rear. This is the only cylinder that I worked on so the problem must lie with this wheel.
Please help before I crash |
06-30-2013, 05:46 PM | #2 |
Re: Help! Brakes pull to left
Me thinks maybe the RRear ISN"T working??
Paul in CT |
06-30-2013, 05:49 PM | #3 |
You could have a leaky wheel cylinder.. which causes the brake to grab. Start by pulling the two front wheels and check them out.
Larry S |
06-30-2013, 05:58 PM | #4 |
Short shoe should be towards the front and longer shoe on the rear .
06-30-2013, 07:29 PM | #5 |
Bendix brakes have the long shoe in the rear but locheed brakes have them reversed.
06-30-2013, 07:33 PM | #6 |
06-30-2013, 07:34 PM | #7 |
Pull the drums off both sides, and carefully check they are both sides the same. Usually if one side needs doing, so does the other side.
06-30-2013, 07:46 PM | #8 |
I checked the front wheel cylinders and didn't see any leakage but I will pull the wheels to check it out, thanks
06-30-2013, 07:50 PM | #9 |
Yes, I bled them several times and got all the air out.
